      Moving a vector object or text between two open files set to be side by side - crashes VS
      palette menu option to select all unused colors does not seem to be working - it selects all
      Aesthetic improvement to palette color selector outline
      @Boldline This problem should be fixed now.
      Right Click Context menu.
      @Jayanta-Das This problem should be fixed now.
    • IngolfI
      Broken color editor section
      @Ingolf This problem should be fixed now.
      Difficulty selecting object with selection warp when it sits overtop another object
    • IngolfI
      Poltergeist in toolbar after customization
      @Ingolf This problem should be fixed in build 1.1.024
    • IngolfI
      Hide spectrum doesn't hide it from prefs
      @Ingolf This problem should be fixed now, let me know if it still occurs.
      Flip and Copy shortcut often goes wonky
      @Boldline This problem should be fixed now, let me know if it still occurs.
      Application crash
      @Jayanta-Das The crashing issue when creating artboards should be fixed now.
    • encartE
      Empty tile in gradient's window
      @encart This problem should be fixed now.
      Paste not always keeping position
      Clicking on a panel let it undocked
      @PatrickM This problem should be fixed now.
      Double click renaming of layers/shapes not working
      Stroke added to an expanded/united offset path causes sections to disappear temporarily, based on level of zoom
    • IngolfI
      Layer right click menu requires double-click (Windows version)
    • IngolfI
      Text overflow bug in shape text frame
    • U
      SVG pasting or importing will result in incorrectly sized figures
      @umauma This problem should be fixed now.
      Resize the "Navigator" panel
      Alignment Panel Seems too Loose
