      Stroke panel not registering stroke sizes under 0.01 - same issue with using the bracket keys
      @Boldline There is a Preferences -> Number Editors -> Limit Precision option: should be enabled by default but it is not (regression), if disabled, the precision should be better.
      Pasted vector in VS and resized, reverts back when copied and pasted
      @Devil-Dinosaur This problem should be fixed in build 1.1.024
    • Devil DinosaurD
      Moving the whole content of a layer
      Ruler 0,0 position
      @Jayanta-Das This problem should be fixed in build 1.1.024
    • encartE
      Double click on text place the cursor in unexpected places
      @encart This problem should be fixed in build 1.1.024
    • encartE
      Double click on existing node doesn't create a new node in the center.
    • IngolfI
      Perfect ellipse values
      @Ingolf The 0 to 360 ellipse angles should not add a line in the next version of VS.
    • IngolfI
      Lock angle (SHIFT plus drag) issue
      @Ingolf This problem should be fixed in build 1.1.024
    • IngolfI
      Pen tool odd behavior
      @b77 This problem should be fixed in build 1.1.024
    • encartE
      Shifted side toolbar.
    • IngolfI
      Stroke, fill messes up
      @Ingolf This problem should be fixed in build 1.1.024, let me know if some problems still occur regarding this.
    • IngolfI
      Properties panel feedback
      @Ingolf (A) should be fixed in build 1.1.024
    • IngolfI
      Issues with duplicate as reference
    • IngolfI
      Jumping and sinking panels
    • IngolfI
      Incorrect naming of duplicate of group
    • IngolfI
      Gradient panel and color panel sync issues
      Alignment will not work if "Space" setting is literally empty
      Toolbar-based warps have a noticeable pullback from where they are released
      Recovered files previously unsaved do not "become" the new file
      Are saved preference files universal between Mac and PC?
      @Boldline When transferring files, the theme might be missing on the other computer. If that is the case, VS will use a default theme now.
