    • encartE
      Lag in Huion tablet while Windows Ink is turn on. Blue spot moves slower than the cursor shape
      @vectoradminit Looks like all lag has been eliminated. Thanks!
      (Win beta 1.0.021) Copy Paste Issues
      Watching Ignoring Scheduled Pinned Locked Moved zoom copy and paste ui improvement shortcut keys too many groups
      20k Views
      @vectoradmin This is great. The default settings are working fine! Thanks a lot!
    • encartE
      The symbols used in the canvas are also edited in the Presets panel
      @encart This has been fixed in build 1.0.044
    • V
      Nudge Moving Distance Issues
      @Vector-Rock This has been fixed in build 1.0.044
      Spelling error
      @Boldline This has been fixed in build 1.0.044
    • encartE
      Microsoft Print to PDF crashes the app.
    • encartE
      Errors when highlighting text
    • encartE
      [Toolbox]Custom shortcuts may change active tool in tool-groups when they are duplicated.
      Spelling error in Actions Menu
    • V
      Contour Panel- Cannot Adjust Width or Precision Values Incrementally with Arrow Keys
    • encartE
      Changing values by scrolling in fields with % unit changes by 120% per step
    • V
      Navigator Panel Object Rendering Problem, Red Navigator Artboard with Keyboard Scrolling Arrows
      Closed offset Path and brush stretching make stroke Disappear
      @vectoradmin This has been fixed in build 1.0.044
      Pen, Brush and Text tool fill colours resetting to transparent or black
      @Kyriakos Sorry for the late reply, but this issue should be fixed now.
      Cannot specify layer color (RC19, Windows)
      @Arde I cannot replicate this issue with the latest Windows build. Is this still a problem?
      VS is completely broken on my system (Mac OS High Sierra)
      @postdes Replicated! Turning off the rulers is the issue.
    • V
      Items Left Behind in Layers Panel when Artboard is Empty
      @Vector-Rock This one can be replicated easily now, and will be fixed. The composite shape was empty because the result from combining the 3 shapes was an empty shape due to a bug. The bug will be fixed in the next build. BTW: in this case one of the shapes is not necessary, as it is the boundary of the other two, and the composite shape is also creating a boundary (kind of creating boundary twice). About the forum images: yes there is some size limit to the images. I will check if this can be increased, but there will be some limit anyway to keep space under control
    • V
      Adjustments to the Guidelines Panel Column Widths not Retained After Closing
      @Vector-Rock Added to the backlog, will be fixed in the next build.
    • encartE
      Imported SVG's are invisible until ungroup & position of imported files
      @encart Got this replicated. It is just a missing refresh issue after importing. Press Control+R on Windows to refresh after the file is imported. Added to the back, will be fixed in the next build.
      Printer marks do not work correctly
      25
      54k Views
      @vectoradmin īŧˆ1.0.041īŧ‰ The basic functions seem to have been fixed. As I mentioned in the previous post, it is better to fix the line widths of marks. Improvement: Each of the following should be set to 0.09mm. -Crop:0.18mm <- too thick -Bleed:0.18mm <- too thick -Resistration:0.02mm <- too thin In actual printing, various data are pasted on the outside of the Artboard as needed depending on the process. However, I think this is sufficient for small office.
