• Text placeholder text improvement
    @Boldline I open a bug, to use the last selected text size when creating text shapes. About the additional tools (scaling) while in text mode. In AD the resize box is shown around the text. I think this could be added later if it does not complicate things too much. In VS the same is achieved by selecting the pointer tool and resizing the text just like any other object (but this deactivates the text tool). One thing that VS has: when editing a shape text (a.k.a point text), when holding Command the baseline can be adjusted as a regular path. And selecting the node tool, will edit the baseline as a regular path.
  • Pinch zoom around cursor
    This is so much better! It's one of those little things that makes a big difference.
  • Zoom and Simplify Path
    syllieS
    @vectoradmin Thanks. Works as expected now (win10).
  • Can the creation of New Layer Not open Dialog Box Each time?
    @vectoradmin This is great! I love the option to hold the option key if you want the layers dialog box to open for a new layer and also the double click of an existing layer to access it that way post-creation.
  • Tool option: erase up to intersection
    30
    69k Views
    Yep, looks good now. Thank you!
  • Pen tool snap to end point
    @vectoradmin Nice, it's subtle and effective. Great improvement thanks!
  • option for layers panel: checkerboard background
    @vectoradmin Build 207 adds checkerboard background in Layers and Appearance panel preview boxes.
  • Offset Path slider option
    Thank you - looks good. just tried it out
  • Scaling jpegs cursor icon
    @Boldline We need some kind of indicator of what will happen at a specific location with the box selection. This can be move, scale, rotate, skew. These are indicated with cursors.
  • Pen tool improvements
    17k Views
    @vectoradmin There are additional improvements for the pen / node tool in the new build 201
  • Bitmaps
    @Boldline I tested this and could not replicate it.
  • Brush default should be plain?
    @fde101 Using solid stroke as a default brush should work in the new build 201
  • New From Clipboard
    @badcat Yes, that can be added.
  • Guideline coordinates during creation
    In build 200, guideline coordinates are shown by default when creating.
  • Allow (better?) keyboard control in Preferences?
    @vectoradmin In the new build (200), up and down arrows should work in browsing the preferences.
  • Handles affecting both sides of node equally in a not good way
    OK I will play around with those setting more - thank you @Jae and @vectoradmin
  • Stroke sizes pre-set
    @Boldline This could be done for the default set.
  • Real time opacity preview in layers panel
    @Boldline Following steps: open both the Layers and the Transparency panels. select the whole layer in the Layers panel, by clicking on the round circle at the end of the row with the layer name. this creates a single object selection, where the object is the layer (can only be done in this way. now with the layer selected, adjust the Opacity slider in the Transparency panel. the result can also be verified, that it applied to the layer (and not those objects) in the Layer Options (or just double click the layer name in the panel). [image: 1609192578232-transparency-resized.png]
  • Some thoughts on tool organisation UI
    Moved interface tools
    22
    62k Views
    Yes, this seems to be working again. Thank you!
  • Visual feedback when using modifiers in shape sketch tool
    20k Views
    Cursor handling improved in build 198
