    2. Features and Ideas
    3. Implemented Features
      Keyboard shortcut suggestion
      @vectoradmin This is great thank you! It's nice that they are already muscle memory for me and I don't have to go change them each time I reset VS in the future! Having these key commands as default is a real help to the "artistic" side of VS I've spoken about - easy to jump in and do quick and dirty adding and erasing of vectors
      Using Save-As on an existing document automatically pulls up existing file location
      @Boldline Should be fixed in build 1.1.002 beta
      Control-B pastes below, regardless of if a selection was made to specifically paste below
    • IngolfI
      Constrain angle improvement
      21k Views
      @Ingolf Fixes to angle constraining and the Anchor tool are available in 1.1.002 beta
      Save warning dialog box when original save location unavailable
      @Boldline This is available in build 1.1.002 (beta)
      Control end caps and arrows of strokes together by linking
      @Boldline @b77 @Ingolf Added buttons to copy left/right cap or arrow options.
      Improving Offset Path panel distance drag
      @vectoradmin There was some improvement to the Distance slider, but no vertical line for now.
      option to recheck for missing fonts
      @Boldline If new fonts are installed, and the "Missing Fonts" view is still open, it will autodetect the new fonts and update accordingly (from build 1.1.002 beta)
      Clicking on Panel name in Panel Menu brings it to the front if obscured
      Option to export/save or better yet, convert selection as BMP file
      @Boldline There is a bitmap export option for BMP files now in 1.1.002 (beta)
    • IngolfI
      Usability inconsistency - thumbnail-icon sizes in panels
      @Ingolf Layers panel menu has been improved in 1.1.002 (beta)
      Resizing panels up to...
      @Jono This issue is fixed in 1.1.002 (beta)
    • IngolfI
      Selecting and moving multiple (many!!) objects
      @Ingolf This should be working in 1.1.002 (beta)
    • IngolfI
      Feature request - clear input field
      @Ingolf This feature is available now in 1.1.002 (beta)
      Node selections should disappear immediately when selected object gets locked
      @Boldline This should be working in 1.1.002 (beta)
      Should Erasing be distinguishable from Path Brush in Editing>History?
      @Boldline Should be correct now in 1.1.002 (beta)
      Keep selection to be erased visibly selected while using eraser tool
      @Boldline This feature is available now in 1.1.002 (beta)
    • encartE
      Drag to set initial font size instead of creating a text frame (as an alternative)
      @encart This feature is available now in 1.1.002 (beta)
      Can Appearance Panel Dropdown menu be set to stay on top of other panels?
      @Boldline Fixed in 1.1.002 (beta)
      Change "Locked" to "Lock" or 'Lock Object"?
      @Boldline Done!
