    282 Topics
    228 Topics
    XRAYX
    @Daniel Morphing between objects with noise transparencies is even more complicated Send me the VS file with that blend effect (second image).
  • Selecting multiple combined objects may cause lag.
    @VectorStyler Here are two files provided: one with combined elements. I've tested it—when this file is closed and reopened, there's no lag during selection. The other file contains scattered elements. You can test further by combining more shapes.
  • Strange circle modification when dragged in layers
    Ok, thanks.
  • Greyed Menu Items
    25
    38k Views
    @fdarnel I still could not replicate this. Also tried on MacOS 15.3.1
  • Dropping colors on selected objects
    I saw that in the new update the problem is solved. Thx
  • Live Text does not get highlighted when dragged over
    @Boldline said in Live Text does not get highlighted when dragged over: Hopefully it’s not too complex a fix Fixed already, it was a resource thing. The issue was caused by showing position in the ruler, and this broke the selection rendering.
  • Latest Vectorstyler version don't launch
    @VectorStyler Sure, it was after auto update from within the previous running version. Can't tell if it was the "universal" one. The manual download was Silicon.
  • Reading of eps files
    @VectorStyler many information is missing. I'll send you a few eps files
  • Selection error
    @monsterfox Another workaround: disable "Snap to Shapes". This feature (dragging objects from a collision point) allows for the rotation and collision of objects at that point to another shape. But: I could still not replicate the cursor showing for unselected objects.
  • Path Offset Panel
    That would drive me nuts, so thank you for catching that
  • Panel error
    @encart said in The font list scrolls to the currently selected font only for installed fonts.: But it doesn't work when I do opposite. I will try to replicate this.
  • "Ghost" object in Layers when deleting ?
    There seem to be several display bugs in Layers. When I past an image in a layer, it only appears after closing and re-opening Layers.
  • Modification of view when clicking on an object in Layers
    @fdarnel Send me a file where this happes.
  • Windows behavior
    @fdarnel Save the workspace with those panels and send the workspace file to my email: csraba at vectorstyler.com
  • Using the Transform tool to select and move a vector is hit or miss
    @VectorStyler thank you for taking care of that so quickly!
  • Polygon Selection - Selection area changes when zooming
    @VectorStyler said in Polygon Selection - Selection area changes when zooming: @Subpath I reviewed this now, and it is not a bug. The zooming / panning allows to reposition the canvas under the selection already drawn. It is by design, the alternate would be to move/resize the selection area with the zoom. Would that be more useful? I only noticed and mentioned it because I was a bit surprised. But personally I don't really need it. I now know how it works and I act accordingly. So I'll leave it up to you whether you think it makes sense if the selection changes, in that case, with the zoom. I think, at least as far as I've tried it, you can only zoom when using the polygon selection anyway.
  • Stripes on strokes/outlines seem to be buggy
    @Subpath This was a regression, and it is fixed now.
    @Boldline I could not replicate this issue. I tried both the the shortcut and the menu command.
  • VS unresponsive/unstable when paired with pen tablet
    @VR said in VS unresponsive/unstable when paired with pen tablet: I also need two other vital feature: a toggle for relative vs absolute brush sizes sizes vs zoom levels on the path brush tool as well as using the most recent attributes by simple selection Question on this: would this mean that when zoomed in, the brush size used while painting (and the stroke width also), will be the same relative to the screen points?
