    291 Topics
    @VectorStyler Thank you for your response. Please note that the lag takes place when you long press the bracket keys.
  • Pencil tool defaults back to a black stroke (instead of "no-stroke")
    @Boldline said in Pencil tool defaults back to a black stroke (instead of "no-stroke"): Is that expected? Yes
  • [macOS] External monitor / locking dialog
    @jkwchui I opened a bug on this.
  • Can't select Selection tools
    Hi sorry I forgot about this for a couple of weeks. It works now. I think my problem was that I didn't realize you had to select the pointer tool before you could click-drag to marquee select. It's resolved, thanks for your help!
  • Inconsistent Dropper Behavior
    @debraspicher Yes, this can be replicated here also. When styles are picked from transformed groups or objects, the transformation is not copied. And since these transforms are non-destructive on the stroke, the original stroke attribute will be copied (without the scaling).
  • A Bug
    @monsterfox I will try to replicate this (sometimes, errors cannot be replicate and then it is not possible to find what is the root cause).
  • Absolute origin patterns on overlapping artboards don't align
    LoginErrorL
    PNG, through the Export Artboards menu.
    @Li-Xiao I opened a bug on this.
    @LoginError Yes, this is a known issue. It is caused by anti-aliasing when shapes are touching precisely and there is a different color background, then at the shapes margin this background will become visible. There is no other solution for now the turning off anti-aliasing.
  • Stretch the brush stroke.
    @monsterfox 不用担心,1.3就有中文了
  • Graphic replacement tool and Repeat panel。
    @VectorStyler https://youtu.be/AcYAcNuuG_E?feature=shared It is also a problem of the replacement tool. After using the graphic replacement tool, a clipping group will be generated in the replacement source, and it is hoped that it can be removed.
  • Trim Path
    @monsterfox I open a bug on this and will try to replicate it.
  • Panel showing behind tabbed Palette Panel
    @VectorStyler I'm sure you received it, but when I did the reset, the program reopened with a Crash report, so maybe that is a help.
  • Cannot Add Swatches.. or so it appears...
    @VectorStyler said in Cannot Add Swatches.. or so it appears...: @debraspicher I can only replicate the panel resizing issue. I can add colors to the palette, with a color selected from the color panel first. It is also possible to drag&drop a color from the color panel target knob (top-left fill/stroke thing) into the palette. I also tested this with the attached file. FWIW, I did test/check these methods. They weren't working either.
    @VectorStyler Sorry missed this. It's the result of the Undo/History bug. Sometimes this happens... I will keep recording and eventually I capture it. It's happened a few times. I'm not sure, but my guess would be the Object was originally meant to be a Layer... (I put everything in sublayers, generally) Edit: I wonder if my habit of Shift + {Click} New Layer/Sublayer might also add something not so nice to the History steps/recipe that might cause Objects that were moved around to get lost, as well? It's just a thought.
  • Adding swatches to default main color panel has issues
    @Boldline I will try to fix this for the next build.
  • Ghost Line request
  • Text Shortcuts not working
    @debraspicher said in Text Shortcuts not working: Are we 100% sure on that? Just because I was testing the Ctrl + V shortcut to see if it even worked at all and that's how I ended up with the Text Frame item Control+V is pasting on Windows. I meant the text frame conversion shortcut only exists on MacOS. What happened with the text frame: when a shape is selected and a text is pasted, then a text frame is created inside the shape, and the text flows into the shape. The problem was that this also happens when the selected shape is a text, and we get a text frame flowing inside the shape of a text. This is allowed in VS, but it should not do it when pasting.
