    292 Topics
  • Source
    @VectorStyler I've found a solution to the first cloning issue by selecting "Copy on Duplicate" in the Duplication Mode. However, the second issue (with the Shape Replacement Tool) remains unresolved. The two options you mentioned are still grayed out in my interface, and I'm unsure how to activate them.
  • Bug in ruler
    Sorry, I was fooled by the zoom level. If I zoom in closer, the ruler actually shows the value 2000. I was fooled by the full extension view, where it shows 1995 near the margin and not 2000
  • Bug
    @monsterfox I will try to fix this for the next build.
  • BUG
    @monsterfox Yes, this can be replicated and it is a bug. Will be fixed for the next build.
  • Two Styles panels
    @monsterfox I will try to replicate this. (for some panels multiple instances are allowed by design, but maybe not in this way).
  • Opposite constrained move?
    @fdarnel Yes, there are some issues here caused by the transforms on the group. I will try to find out more about this.
  • Problem selecting layer name
    @fdarnel Got the recording, I will try to replicate and fix this.
    @Daniel Morphing between objects with noise transparencies is even more complicated Send me the VS file with that blend effect (second image).
  • Selecting multiple combined objects may cause lag.
    @VectorStyler Here are two files provided: one with combined elements. I've tested it—when this file is closed and reopened, there's no lag during selection. The other file contains scattered elements. You can test further by combining more shapes.
  • Strange circle modification when dragged in layers
    Ok, thanks.
  • Greyed Menu Items
    25
    38k Views
    @fdarnel I still could not replicate this. Also tried on MacOS 15.3.1
  • Dropping colors on selected objects
    I saw that in the new update the problem is solved. Thx
  • Live Text does not get highlighted when dragged over
    @Boldline said in Live Text does not get highlighted when dragged over: Hopefully it’s not too complex a fix Fixed already, it was a resource thing. The issue was caused by showing position in the ruler, and this broke the selection rendering.
  • Latest Vectorstyler version don't launch
    @VectorStyler Sure, it was after auto update from within the previous running version. Can't tell if it was the "universal" one. The manual download was Silicon.
  • Reading of eps files
    @VectorStyler many information is missing. I'll send you a few eps files
  • Selection error
    @monsterfox Another workaround: disable "Snap to Shapes". This feature (dragging objects from a collision point) allows for the rotation and collision of objects at that point to another shape. But: I could still not replicate the cursor showing for unselected objects.
  • Path Offset Panel
    That would drive me nuts, so thank you for catching that
  • Panel error
    @encart said in The font list scrolls to the currently selected font only for installed fonts.: But it doesn't work when I do opposite. I will try to replicate this.
  • "Ghost" object in Layers when deleting ?
    There seem to be several display bugs in Layers. When I past an image in a layer, it only appears after closing and re-opening Layers.
