    292 Topics
  • Modification of view when clicking on an object in Layers
    @fdarnel Send me a file where this happes.
  • Windows behavior
    @fdarnel Save the workspace with those panels and send the workspace file to my email: csraba at vectorstyler.com
  • Using the Transform tool to select and move a vector is hit or miss
    @VectorStyler thank you for taking care of that so quickly!
  • Polygon Selection - Selection area changes when zooming
    @VectorStyler said in Polygon Selection - Selection area changes when zooming: @Subpath I reviewed this now, and it is not a bug. The zooming / panning allows to reposition the canvas under the selection already drawn. It is by design, the alternate would be to move/resize the selection area with the zoom. Would that be more useful? I only noticed and mentioned it because I was a bit surprised. But personally I don't really need it. I now know how it works and I act accordingly. So I'll leave it up to you whether you think it makes sense if the selection changes, in that case, with the zoom. I think, at least as far as I've tried it, you can only zoom when using the polygon selection anyway.
  • Stripes on strokes/outlines seem to be buggy
    @Subpath This was a regression, and it is fixed now.
    @Boldline I could not replicate this issue. I tried both the the shortcut and the menu command.
  • VS unresponsive/unstable when paired with pen tablet
    @VR said in VS unresponsive/unstable when paired with pen tablet: I also need two other vital feature: a toggle for relative vs absolute brush sizes sizes vs zoom levels on the path brush tool as well as using the most recent attributes by simple selection Question on this: would this mean that when zoomed in, the brush size used while painting (and the stroke width also), will be the same relative to the screen points?
  • Minor preview bug in shape effects
  • Wrong transformations
    Now it works. I would have never realized by myself. I thought that the conversion to curve was only needed on the object alone, not also on the root layer. I hope to get familiar one day with all these hidden tricks, which make this software so powerful Thank you
  • Working with Minified Panels, unintended behavior?
    @debraspicher This should be fixed in the 1.2.061 build
  • Program crash when opening panel menu
    nocturnalYLN
    I can confirm that this is fixed. The minised panel icons are now always responsive, and clicking on the ≡ icon on expanded minimised panels no longer crashes the program.
    nocturnalYLN
    I can confirm that the unresponsive UI issue I described is fixed.
  • Multiple issues
    @MikeI said in Multiple issues: @VectorStyler Ok cool. Here's the video showing how the font selection jumps to full screen: Video I opened a bug on this.
  • Recolor woes
    26
    31k Views
    @VectorStyler As already said thats only happen when using the Mouse scroll wheel in that Number fields, the arrow keys work expected counting 1, 2, 3° ect
  • Number skipping or weird behavior of arrows at number fields
  • Text Link
    @hbalcic Got it, I will try to fix this.
    @Boldline This should be fixed in the 1.2.060 build
    @VectorStyler said in Raster images embedded go wonky when the "frequency slider is used in the Image Effect panel -also could we image trace an image effect with image trace?: For tracing image effect: first you need to rasterize them into an image (Object -> Rasterize) and you can use trace. This should work on halftones also, but you may need to make a small tracing tolerance, use Black and White tracing mode, and when rasterizing, use a high resolution so that there is enough detail in the halftone. Thank you for the reminder about rasterizing it first... that worked! I appreciate your tips as well for best results
    @Boldline Yes, if the repeater scaling mode is set
  • Snapping Ignore Modifier (Ctrl) Sometimes Ignored
    @debraspicher One thing to remember: in VS pressing a modifier before the mouse pressed and after the mouse pressed can have different results depending on the tool (by design).
