    3. Resolved 1.2 bugs
      Does VS necessarily have to close open unsaved files to be able to check for an build update?
      @Boldline I will try doing that. I think the problem was with the type of exit used by the Sparkle updater, I have to check that.
      Clicking on artboard using the shift modifier deselects what was already selected
      @Boldline @larsherold it is a regression.
      After replacing the graphic, there is a deviation.
      @VectorStyler This problem has been fixed.
      Unretrievable graphic effects
    • AyoA
      Show selected problem while 'Show starting and ending nodes OFF'
      @Ayo Got it, I will try to fix this.
    • AyoA
      Color Variations incorrect display color value first steps
      @Ayo Yes, maybe the toning starts one step late. I will fix this.
      Click and Drag to Add to selection is not working in new build 31
      @Boldline The problem can be replicated. I will release a fix today.
    • debraspicherD
      Doubling, tripling, etc, of interface after waking up PC from sleep
      @VectorStyler I'm also facing the same issue, but I didn't put my computer in sleep mode. I simply didn't close VS for a few days. This computer is one I occasionally use, and I never shut it down. After being away on a business trip for four days, I came back today and tried to open a file on this computer, only to encounter this situation. The OS is Windows 11. [image: 1720430696260-interface-resized.jpg]
      Image effect: "opacity" ? bug?
      @Pat said in Image effect: "opacity" ? bug?: I suppose that these two opacity-control sliders are not redondant ? Should not be.
      a bug
      @monsterfox Yes, can be replicated here also. In this case, reference objects must be expanded first (Styes -> Expand Symbol). I will try to add this to be done automatically.
    • debraspicherD
      Transform panel refusing coordinate input for guides on occasion
      @monsterfox said in Transform panel refusing coordinate input for guides on occasion: Please fix this problem. I opened a bug on this.
    • debraspicherD
      Color Panel + Spectrum mismatch causes Hue shift
      @debraspicher I will try to replicate and and find a solution
    • debraspicherD
      Artboards copy a 3rd Artboard and span the entire Canvas after unchecking of Artboard Coordinates
      @debraspicher There are also "export slices" in VS, can be used to mark an area of the canvas for exporting, and can include regions of multiple artboards.
    • debraspicherD
      Navigator View Presets are not working as expected
      @debraspicher said in Navigator View Presets are not working as expected: The shortcut, or at least I suspect it is the shortcut, for Switch Document View doesn't appear to work The shortcut is to switch between different views created with the View -> New View command.
    • debraspicherD
      Despite selecting a new Layer, sometimes it moves the Last Selected
      @debraspicher This is only a partial bug (in that sometimes it does not work), and that part will be fixed. The (existing) feature part is that if something is selected in the layers panel (strong blue highlight) and the key input is still on the panel (mouse last clicked in the list), then a shortcut action will be executed on the layers panel selection. For example, select two items in the Layers panel and press Control+G, it should group these two (not what is in the canvas), unless the user clicked away from the panel.
      Offset between a cloned object and contour after blending
      @VectorStyler Thanks for the feedback. No hurry for me. I report anything that can be considered a bug
    • AyoA
      Transform Selection Node Sizes Selector not working
      @Ayo I opened a bug on this.
    • IngolfI
      Page repositions or similar after some time minimized
      Might explain why the canvas always ends up offset for me.
    • debraspicherD
      Transparency Panel Dysfunction
      @debraspicher Got it.
    • AyoA
      Typo
      @Ayo Will be fixed.
