    @Boldline Drag the detached document from its title leaf (the "Untitled..." text in the image) and drag it over the area where the attached title leafs supposed to be. There is a thin gray line indicating the area.
  • How do I pull out a tabbed panel from a group?
    @VectorStyler Thanks. I realized that I had to click off on the "lock all panels" to allow the tabs to be easily pulled out from a grouping.once I unlocked it, I was able to edit the groups of panels as you showed in the video
  • Specific values in Grid
    @VectorStyler Thanks for the support. Will try that.
  • Repeated clicking does not drill down to lower objects to select
    @Boldline Only if double clicked for isolation. Or with Option+Click to select an object inside a group.
  • VS update?
    @asan The next build should be on app store also (this week).
  • Performance issues with Illustrator brushes
    @JuurGroove said in Performance issues with Illustrator brushes: Though still not as smooth as in Illustrator as far as I can remember When ypu have time, test those scatter brushes against any of the recent Illustrator releases
  • Confused about transform
    @VectorStyler I'll get some examples next time I start fiddling especially now that I know the zoom matters for snapping
  • Bug Report Window Suggestion
    @debraspicher I will fix this.
  • Altered pivot point doesn't apply
    Very nice upgrade v. 1.2.057 Now transforming with Transform tool (V) works fine. [image: 1737467958863-5ebaca52-23b2-4d66-a6b7-3080a9c4cb95-image-resized.png]
  • About page
    31
    39k Views
    @VectorStyler I don't think it's necessary. This seems like an action where there are two steps: 1. Create a new canvas, 2. Maximize the canvas display. The shortcut key operation is just for the convenience of adding a canvas. I have also set a separate shortcut key for maximizing the canvas display. I believe most people share my view. This is more in line with the actual operating habits.
  • Roadmap & website
    @VectorStyler thanks, I always end up finding it... I humbly think that this information is interesting for those who visit the website without being particularly interested in the forum.
  • How to disable value fields scrolling?
    @JuurGroove In Settings -> Number Editors -> Scrolling Mode you can select when you are able to scroll a field.
  • How do I links to email and urls i VS?
    @Boldline I have only basic understanding of how software development works, but I wouldn't be so confident in hoping you could just like that reutilize VS's framework for building up a totally new raster application without massive amounts of development work. This right here seems to be one of my main issues with Affinity Designer, that it has never been built up as a true vector application, and till this day it's struggling a lot with even the most basic vector functions. Most of its "vector" features seem to be in fact just mimicking vector behavior, but. the output is still bitmap. Like patterns or even brushes, which they have the audacity to market and sell as "vector" brushes on their store. FWIW Affinity Photo is a great Photoshop replacement, if you don't rely on generative AI that is.
  • Website carousel navigation missing
    @syllie Yes, it is fixed now!
  • Keyboard Shortcuts for Alignment and Distribute Functions
    @JuurGroove This is only possible now as a recorded action (using Actions panel). But I can add some predefined actions of the common alignment types.
  • How to use color picker in color panel?
    @Li-Xiao @VectorStyler So cool. Thanks. Now I got it (this image for my own VS-guide): [image: 1736336590071-68ac48da-3501-45cd-a08c-fb1a84bed344-image.png]
  • Wide Color Gamut
    D
    I appreciate the quick response. I have attached the Display P3.icc file. It is part of the macOS system. I tried the 16-bit setting in Display Options, but there was no change in VectorStyler. Regards, David Brown 0_1735939455626_Display P3.icc.zip
    @VectorStyler said in 1.2.054 update caused dark interface with menus/menu texts invisible (also dark), how to return to light interface?: @Arte said in 1.2.054 update caused dark interface with menus/menu texts invisible (also dark), how to return to light interface?: After deleting the backup config file it worked normal again. was this the "config.ini" file? Yes
  • Software interoperability
    @VectorStyler 22.0.1
  • License verification failed
    FWIW, I had the same error when I registered just now on a separate machine and it claimed server couldn't be connected. I hit Retry and heard nothing back, saw it had the "Remove License" option in the Help menu... on restart, no nag screen, so I guess it is registered...
