    @VectorStyler Thanks for looking into that and finding a solution for now and in the next build.
  • node editing tool
    @VectorStyler I just tested CorelDRAW again, and the result was the same as that of Inkscape and Designer.
  • Color Picker + cmd modifier
    @Ayo said in Color Picker + cmd modifier: For consistency and to please ex Illustrator customers it would be nicer in my opinion to use cmd+ for Drawing Tools for positioning and sizing I will try to change this after the next build
  • Auto-trigger Path/Node Options
    @debraspicher Should the preview for these node commands be a separate option ?
  • Auto reset transformation
    @Ayo said in Auto reset transformation: Disable for the time being? Yes.
  • repeat
    @VectorStyler I usually have a relatively large workload, and most of it involves repetitive operations. Therefore, I will try my best to reduce the operations as much as possible. Typing with the keyboard will invisibly add some amount of operations (and directly using "Larger nudging" is faster).
  • Data Sources - how to import " (quotation mark)
    @Harry This is a bug, the root cause was identified and the fix will be in the next build.
  • How to skip empty artboards while exporting?
    @Harry said in How to skip empty artboards while exporting?: It's a bit confusing now. I think it would be clearer if the "Export Artboard" panel didn't show excluded (empty) artboards. The way it works now: the artboard export settings can be saved and recalled as presets and also using the Export Again. If the the content of the artboards is changed, the "Export Again" will also adapt to the new empty/used artboards, if they were selected.
  • Uniform Stroke Scaling problem
    @Ayo said in Uniform Stroke Scaling problem: Why lives"Transform Content" and other transform options well, in the appearance menu anyway? These are options of the style items listed in the Appearance panel.
  • "Magnetic node tool" available in VS?
    @VectorStyler That's nice, thanks With liquid-tool/magnetic I find options I need: Interactive control of fall-off/"brush"-size and the option to transform node clusters without adding new segments. Very useful when adjusting shapes to a background sketch without metriculously tracing it segment by segment [image: 1728468719111-e6249b90-4f7c-499f-b3e2-9f98077a33f5-billede-resized.png]
  • Getting my head around abstractions
    @jkwchui said in Getting my head around abstractions: preset style symbol clone Overall description of these features across programs that support them: Preset Definition: A preset is a predefined collection of settings that can be applied to objects in your design. Example: When you choose a preset for a shadow effect, the program automatically applies the desired settings, such as the specific size, color, and opacity of the shadow. When it's useful: Presets are great for saving time and ensuring consistency in your design. If you frequently use the same effect or style, you can quickly apply a preset without having to manually adjust the settings each time. Style Definition: A style is a defined way of formatting an object, which can include various attributes like color, outline, shadow, pattern, etc. Example: If you create a text style for headings in your designs, you can use the same style on all your headings, making them uniform in appearance with a single click. When it's useful: Styles are ideal for maintaining a cohesive look across multiple elements in your design. When you change a style, all objects using that style update automatically. Symbol Definition: A symbol is a graphic element that can be reused in multiple places in your design. When you modify the symbol, all copies automatically update. Example: A logo or icon used on several different pages in a brochure or web design. If the logo needs to be updated, you change it once, and all instances are updated automatically. When it's useful: Symbols are perfect for elements that appear in many places in your design and need to stay consistent. This saves time and ensures visual uniformity. Clone Definition: A clone is a copy of an object, but unlike regular copying, the clone is linked to the original, so changes to the original automatically update in the clone. Example: If you have a shape that needs to be repeated multiple times in a pattern, you can use clones so that you only need to change one shape to update them all. When it's useful: Clones are extremely useful when you need to create many repetitions of the same element but still want the flexibility to change the design later without manually updating each copy. In other words Preset and style are best for keeping your design settings consistent and save time with repetitive tasks. Symbol and clone are perfect for repeated elements where you want changes in one place to automatically update all instances. If you come from Circus Serif and Affinity If you have used Affinity, note that graphic styles in Affinity are simple, static, primitive presets because the company doesn't understand the terms behind what they are trying to implement. Vectorstyler has true styles, and they are genuinely useful, just as styles are useful in all other design programs, word processors, and websites. Styles are extremely valuable for professional and structured, organized graphic designers.
  • Pattern Brush Style
    @VectorStyler That's fine for a certain range of stroke thicknesses, otherwise the deformations are too great. Scaling must also differ depending on the shape. It's getting complicated...
  • Shapebuilder, Intertwine?
    @Subpath Thank you!
  • Can't paste copied or cut shapes in memory
    @VectorStyler I Understand. Good idea is using break apart paths and combining shapes for optimal drawing/file structure.
    @Boldline Yes, this is a known bug, and it is MacOS version dependent.
  • about choice
    34
    50k Views
    @VectorStyler 0_1727698512968_6.vstyler
  • Panels do not save their position
    @VectorStyler Files sent
  • Duplicating a Path Section - per manual, doesn't seem to work
    @VectorStyler said in Duplicating a Path Section - per manual, doesn't seem to work: @Subpath The 3 node limit is because of a conflict with an other feature, where the Alt+ with 2 node selection will stretch the section between the two nodes. understand, have no Problem with that, (just wondered) if i need it i will add a node if necessary and deleted it later on
  • what file format from Shortcut Presets in vector styler
    @re said in what file format from Shortcut Presets in vector styler: adobe-illustrator-cs2.xml Can you send me this cs2 shortcut file by email to csraba at vectorstyler.com I only have AI CC, I'd like to check if these are compatible.
  • A suggestion for numbers in the workspace
