• Prevent a layer to expand on click-drag
    @VectorStyler Fix confirmed
  • Unexpected Result doing Boolean Exclude with a Bitmap
    @Subpath Yes, this is a known issue. A workaround: place the image into an other clipping shape (can be a rectangle of the same size). The image can be drag&dropped into this clipping shape in the layers panel. Then use the boolean exclude on the clipped image. This will exclude from the clipping and not the image shape, so the image size will not be changed.
  • Export svg to Mac HD fails when entering alternative name
    @VectorStyler Works fine now in new version!
  • How to hide outline stroke segments?
    @VectorStyler Cool! Thanks
  • Purchase issues
    @lilith 加个QQ?
  • Distinguish keyboards
    @monsterfox said in Distinguish keyboards: The shortcuts for the main and numeric keypads are not separated. I will try to find a solution for this.
  • Non-destructiveness vs new (visible) reality
    @Subpath I am not specifically concerned with more or less functionality, but with the difference in behavior with the same functionality.
    @Daniel There seems to be an issue on Windows with this. I opened a bug.
  • About images
    @monsterfox I added these to the backlog (1) and (3). The problem for (2): all images are clipped (in a rectangle initially, but clipped), this clipping "frame" can be styled with fill and stroke, just like any other object.
  • Expanding fill patterns
    Thank you so much
  • How to snap handle to the tangent line?
    @VectorStyler Thank you. It's an important function for things like lettering/logotype. An easy example, if someone is designing a custom typeface that's based on a skew, having a snapping feature would speed things up for getting those clean curves...
  • Bending and Arching editable text objects fails
    @VectorStyler Ah, I confused "Convert to Shape Text" with "Convert Frame Text to Path". Thanks! [image: 1741712885586-38216545-7162-4799-9ba7-e4817a1068ec-image.png]
  • Shape Effects, vector handles unresponsive
    @VectorStyler Ok, makes sens
  • Feature repair
    @monsterfox I added this to the backlog.
  • How to change parameters by scrolling in the text boxes?
    @Daniel This behaviour works in panels and views, but not in the context panel (upper row).
  • Apple mouse wheel use
    Thanks!!! It seems you also have to restart VS.
  • About Hiding
    @VectorStyler https://youtu.be/gOM3Fp3GIW0?feature=shared This video should be understandable. Hiding and showing will not be counted as part of the operation steps.
  • Snap to points
    @monsterfox I added this to the features list for later.
  • Where is the option in context bar to change default pen tool mode?
    @VectorStyler thanks! I figured out if I turn off the symmetric nodes and the "show segment" options, I get the pen tool settings that work best for me. With your Command+ option, I see it can give me pure cusp nodes when using the pen tool. that can be useful [image: 1741187704496-270a437d-9824-44b9-b04c-cd1d6e78f3d0-cleanshot-2025-03-05-at-10.14.35.png]
  • The square tool has no control points.
    @monsterfox To resize a rectangle without distorting the corners, enable the Settings -> Editing -< Direct Shape Transformation option.
