• Single click fill select
    @VectorStyler said in Single click fill select: Clicking again will select the next object behind the selected one Works very nice, without modifier key!
  • Instruction for customizing icons?
    @Ayo said in Instruction for customizing icons?: Can someone give me a suggestion where I can find an instruction for customizing icons? Any post or video somewhere? I want to change an existing icon. Which is possible according to the documentation. The online manual v1.1.085 is too general about this. The only way for now is with Symbols, as described by @b77
  • Canvas (background) color to white?
    @Ayo Nice!
  • Installation Apple Silicon to Universal
    @Ayo said in Installation Apple Silicon to Universal: I hope that two installations are allowed. Yes allowed, including Windows. You can freely choose which one (Universal, Apple Silicon, or Intel) version. When updating, it will keep the selected one.
  • Editing prefs proposal
    Thanks! Just purchased a license! The download server from Finland is already for a few weeks slow 11kb/sec. Have the Russians cut the cable or is it my problem? Three hours to go according to the download indicator. @VectorStyler said in Editing prefs proposal: All comments are welcome and please feel free to comment (even negative ones) in the future. This is the only way VectorStyler can be improved. Right! Did they actually sue Adobe, and got some coupons? Also, I think the main guy there started to do Gravit (not sure). I believe they never came that far. And yes, frontman started Gravit. In the beginning shared his progress and first drawing tools following the Freehand philosophy regularly online. Later it became quiet. Now it looks like sold to- and become a part of Corel. yes, this would be great to know. You are eager! @Subpath ps: it sounds to me that your german ? Dutch as I mentioned
  • Image effect: outer glow
    @Pat Should not change the opacity, but it replicates here also. I will try to fix this ASAP.
  • Magnetic snapping >
    Thank you! That was very helpful. Obviously the lines had problems with the snapping settings.
  • Text distortion: adding a stroke (after)--> changes the text size
    @VectorStyler I'll send you this file again asap. The fill colour of one of the contour object can not be changed.
  • Contour tool
    @Pat Seems to be a bug, will be fixed ASAP.
    @Boldline said in Live text still shows wrong font size when scaling with transform tool: I reopen this issue, send me that example from the screenshot. Should live text be immune to shape effect completely? It cannot be.
  • Layers panel: seeing only the layers of a specific artboard...
    @Pat said in Layers panel: seeing only the layers of a specific artboard...: but what if I need to compare design/schemes/graphics between artboards & eventually copy/paste some objects ? It is possible to open additional views of a document, with each view showing a different canvas.
  • Adding object attributes annoyance
    @Igull Also: clicking on the button that opened a popover should close the popover. The problem with using the Esc key is that after selecting the color (first click), the key input assigned back to the document and Esc is used as a shortcut or to close the isolation mode.
  • Scale VS workspace to fit fully on screen
    @Boldline Did you try a two-column toolbox? (Panels > Toolbox Style > Two Column)
  • Unable to add a new color to an existing color palette
    @Boldline OK, good to know. Well, dragging a color to the Color Palette Bar to add it there would be nice, I agree.
  • Image effect: on individual or grouped objects
    @VectorStyler ok great, good to know
  • Set VS to paste vectors on selected layer and not top layer by default
    @VectorStyler ok it's working on a fresh reboot of VS. The vectors imported had been from another VS file. I initially thought it was a setting to swap, like a "always paste to top layer" and not a bug or restart issue - hence why I had posted the question. All set for now
  • Distribute objects with value?
    @Igull is even possible to do some Math here [image: 1687774111707-copy-each.png]
  • Blending & alignment of objects
    @VectorStyler Nice to know, looking forward to v1.2
  • Layer panel: to select several objects
    @Pat Swiping through multiple round knobs will select those. I added the Shift+ thing to the backlog, maybe it should select between.
    @VectorStyler said in Sometimes double-tapping the "L" key to convert a node to cusp gives me the path sketch tool instead: Looks like that if the command fails (already cusp), it falls back to default. Yes! You put that so succinctly! That would be great fix. Thanks
