• Why did "Actions" disappear from the Preset Manager's Preset list?
    @VectorStyler Ah, that's right! That's what it was! I knew I added the actions to the Preset Mgr somehow but I forgot how I did it. SELECTION! You have to select the group! Yes, that's what it was. It's not as obvious because the only indication that the group in the Action panel is selected is that more icons get enabled at the bottom of the panel. And it's easy to overlook. Maybe because I'm using a dark theme...? Will have to see how the light one looks.
  • Weird line on hover
    @pentool There is a bug with composite shapes containing transformed shapes. Can be replicated here also, will try to fix ASAP. As a workaround, convert all (including the lines) into curves before making a composite shape. That will "bake" the transform into the lines.
  • Weird preview line after editing a node with the pen tool
    @pentool said in Weird preview line after editing a node with the pen tool: Once you adjust/edit a node with the pen tool and then want to continue drawing the line, the preview segment will be heavily curved. It should be straight because the last point is a cusp node. Added this to the backlog.
  • Contour Tool > Smooth Steps - no changes
    @pentool Added this to the backlog, looks like a bug.
    @pentool it is the Eraser checkbox, I will update the documentation.
  • UI Theme: "Size:"
    @pentool Some resource name referencing issue (again), will be fixed ASAP.
  • Weird frame
    @Ingolf I will try to replicate this.
  • How do I change the color of all text of a certain color?
    @Boldline Select by shape (and other selection) commands cannot select parts of the text only. I tested this, and here I get all text shapes selected as objects. So only the use of color styles remain for this.
  • Snapping Gap vs Snapping Tolerance
    @pentool There might be a bug here, will be fixed ASAP.
    Try moving the shape - and the text will move with it. Select the shape first (not the text). https://www.youtube.com/watch?v=6KmANbdIt7w
  • Copy Option/drag object constraign angle 45 degrees.
    @VectorStyler said in Copy Option/drag object constraign angle 45 degrees.: @Ayo I will add the diagonal case. 1.1.095 Simple but feels much better now. Thanks
  • Why I'm getting double grid snapping guide lines?
    Well, there are a LOT of grids. There are reference, parent and artboard canvases. They all can have grids (they have a little grid icon next to them in the Canvas & Artboard panel). Furthermore, all these canvases can have any number of artboards and they all can have grids. Phew... So even if you delete all the grids (in the Grid Editor) for all canvases and artboards except the artboard you are working on, you'll still have this issue. So not sure where the extra set of grids are hiding, if there are any.
  • Xform rotation angle precision
    @pentool No option for this for now.
  • Documentation: No "Limit" options for Grid Panel
    @pentool Yes, it was removed from the panel and only available in the modal view. I will update the documentation.
    @pentool After a bit more inspection, the bug was only half fixed. Additional fix will be in the next build.
  • Cannot delete actions. Cannot create new action folder.
    @pentool I will try to replicate this. It might be a bug in how custom actions files are handled.
  • presetname.adjustmentfilter
    @pentool It is a missing text resource name, will be fixed in the next build.
  • Why am I getting these weird line working with the Anchor Point Tool?
    @pentool THat last line is the control point and handle of the curve to be continued by the pen tool. It should not be visible in the anchor point tool, I will fix this ASAP.
    @Boldline Yes, this could happen with certain curves (control points aligned on the curve, or retracted to the ending). Send me that shape, and I will try to improve this.
    @pentool The Place tab is not shown when the app edits options of multiple artboards. But I have to check why does it think that there are multiple artboards selected in this case, could be a bug.
