• New computer: Vectorstyler does not accept license key.
    22
    31k Views
    @Gremriel I added this to the backlog and will try to replicate it.
  • It is not clear how to use Reference Canvases
    @pentool Added this to the backlog and will try to replicate.
  • Why edit corner point is off?
    Thanks, yeah, I did not convert it to curves, maybe that was the issue.
  • No editing handle visible for spiral gradients
    @pentool The spiral gradient shape cannot be edited as a shape, you need the concentric or axial modes for that.
  • DOCUMENTATION: Gradient Panel menu > Flip Colors
    @pentool Will be fixed.
    @Boldline The print preview is wrong in this case.
  • Section 3.9 Path Panel in the manual: Where is the Path Panel?
    @_NM_ This is a bug in VectorStyler that I could not replicate it yet here. Somehow the old resources (text in this case) end up in the user folder (probably) and the new version after updating ends up using the old resources.
  • Create your own palette
    The idea here is that if you get a brand guide from a client specifying, say, 5 colors, you want to create a palette that contains only these colors. I don't need 128 other "default" colors. Just the brand colors for this specific project. There doesn't seem to be an easy way to accomplish this.
  • Clicking Existing live text box does not allow for easy editing
    @Boldline What font was used in that text?
  • Add texture as Mask
    @Boldline These control how the mask content is transformed. I will have to test this, how it applies to this case.
  • Effects > Blend > Blend
  • Change width/height by 10 using SHIFT
    @pentool I had a similar issue, the keyboard shortcuts for 'nudge more' /left/right/up/down (shift arrow) had 'unknown command' next to them - I just removed the commands and made another four - then saved the command set - solved my problem - YMMV Neil
  • VS Performance Issues
    @_NM_ I managed to replicate some refresh performance issues occurring after changes. I will try to improve this.
  • Just puzzled about canvases and such...
    I don't think it has to do with terminology. As @VectorStyler said, this is a new concept that is not found in any drawing/graphical/design app. So I'm trying to think like when a new user (beginner or advanced or whatever background) test drives this application and finds this "multiple canvases" concept with parents and children and reference and artwork and roles and so forth. As someone (the new user) who never seen the existence of such feature, how will they react to this? Say, on a scale of 1-10 how easy it is not only to understand but also to apply and use what multiple canvases offer in practice? Let's say they open the Canvas & Artboard Panel and they see "Reference Canvas" and you were to ask them "What do you think this means? What does this do? Why is it called reference? Does it reference something, if so what?" What would they say? How easy it is to guess what the role of a reference canvas is? People who come from the world of Adobe, Affinity, Autodesk, Maxxon, or any other products that has a document, canvas, artboard, and layers, how easy it is for them to understand the concept? Not to mention the world of "roles" that can be attached to the canvases. The way I see it, there are two options: They dig in and try to understand They don't understand, get confused, and one way or another they give up because they don't care. Now, let's assume there are bugs lurking in the various canvases and their roles and options. If people find all this confusing and they don't dig in and try to understand how all this will be beneficial in a design, the bugs will never be discovered. You will only discover bugs if you start using it in a project. But if it's confusing, you don't understand, or just don't care, then you will never use it. If most users will never use it, then what's the point having it? Just to have it there? Is there anyone who is actively using this application in the past 2+ or so years took advantage of these multiple canvases and their roles and hierarchies in a project? Look at @b77's question above. I assume he is using this app for awhile and yet he still has questions for not understanding certain concepts about it. If something is overly complex, does it encourage users to use it? I read the manual about multiple canvases and roles and many things are still not clear. Anyhow...just thinking out loud.
  • Artboard 1 uses a Reference Canvas. Now what?
    No, it was just an empty document with a circle and a star in it. I don't seem to be able to recreate it at this point, but when it happens, I will save it.
  • Selecting Paths and Objects
    @_NM_ said in Selecting Paths and Objects: It is perplexing when the selected canvas and layer differ. I Welcome to vectorStyler. Yes, the selection in the Layers panel and on the canvas are different. These can be synchronized (Layers panel menu -> Panel Options) if needed. This mode (similar to how it is done in Adobe Illustrator) enables some features between the canvas and Layers panel.
  • Collision snap incorrect
    @pentool Replicated here also, there seems to be a precision issue in this case. I will try to fix this ASAP.
    @pentool Yes it is related, but it is a feature. Selecting rotated artboards will rotate to view to align the artboard for editing.
  • Force VS to only allow a specific sublayer shape to be edited?
    @Boldline Active shape is something else. I think this should be an option of the Node tool, whether to allow selection of other shapes, while a shape is already selected.
