• Paste Below place objects in between initial selection
    @encart Can be replicated! Added to the backlog as a bug.
  • Inking Process Help
    30
    61k Views
    Great! This would offer a solution the times users want to make use of the pressure option and still expand and divide those pressure based strokes. Thank you!
  • Awesome work!
    @Boldline Thanks a lot! Things are progressing normally. I decided to postpone this weeks (Mondays) release to have some much needed features added. But the release should be out later this week, or latest on Monday
  • kerning and leading
    @Boldline Leading will not help in a single line text. Kerning will only work, if there are kerning metrics defined in the font, and those are then scaled up/down. To uniformly adjust distance between character, you need to use Tracking, that is set in the field with the Ta icon (just under the kerning label).
  • snap handles into nodes status
    @vectoradmin and @Boldline As I said, I would like box selection to work also for multiple handles, but it would be a problem if 'Select Nodes from All Objects' is not disabled in Prefs > Editing Options. What would be an elegant solution? /\/\/\/\/\/\/\/\/\/\/\ EDIT: What if the app would restrict the nodes and handles that can be selected to the selected object(s) by default, and only if nothing is selected allow the selection of nodes & handles from all objects? This as the default selection rule when in node editing mode would make more sense to me at least, solve the problem above and generally simplify things (probably make the 'Select Nodes from All Objects' prefs setting redundant).
  • Questions about rotating an object with two different centers
    @861475_VctSt (d) is a bug.
  • Ungroup All takes a lot of resources?
    @Boldline It depends of course on what is ungrouped, but it should not freeze up the machine or take too much time. I add this to the backlog.
  • Merge Boolean
    @Boldline Yes, it seems that there is a bug there.
  • cut and merge variable width profiles with the pencil eraser mode
    @Boldline The problem with brushes is that the content of the brush cannot be cut. Cutting and merging the width profile can be done (added this to the backlog), but the brush content from one of the shapes will be stretched out on the resulting shape if the Merge option in the context panel is checked.
  • Can't find select same fill colour
    DazmondoD
    @vectoradmin Thank's
  • Questions about Style two-step editing
    @vectoradmin I can also duplicate the item with Duplicate and make changes and adjustments. It's not cool. Could you please re-examine? By the way, I mainly make the Styles palette resident and control Style. I don't use Character or Document Styles much.
  • Is it possible to specify a number of steps in gradients?
    @Arde Not possible to have limited steps. Object blends can be used for fixed step color transitions. Would such a feature be useful otherwise? EDIT: it is not difficult to add such a feature.
  • modifier key for drawing a centered ellipse on mac
    @vectoradmin By the way, loving the control I have with the shapes panel. VS gives me so much freedom and control
  • Unable to register Printing Style.
    @vectoradmin thanks I overlooked it. i got it
  • Path Brush tool honors existing color on artboard over palette choice
    @Boldline I added a path brush tool improvement task to the backlog.
  • Bitmap and layout apps?
    18k Views
    @Petar_MK @Kyriakos Doesn't VS already have some bitmap halftone kind of function built in already? I agree with @vectoradmin that it's probably important to not stray too far from keeping the application a vector-based focus. That said, the ability to do a few things in raster is helpful - I need to play with it more, but the halftone bitmap abilities already inside VS are awesome
  • A very naive question about document settings.
    @861475_VctSt Yes, that will work fine.
  • Global colors?
    Thank you.
  • Large strokes glitches
    @encart This is a known open issue. The problem occurs at the cleanup phase after offsetting. There are a number of stroke and offset bugs related to this. It will be fixed, but it is a challenging issue
  • VectorStyler and Wacom Cintiq 27QHD (Windows)
    cintiq windows
    @Gremriel This looks like a bug.
