• Second chance for pick a key object in alignment
    @mtinra said in Second chance for pick a key object in alignment: Sorry for flooding the board. Feel free to post as many ideas, bugs and questions as you have on the forum. I have personally benefited from many questions and answers as well as the suggestions others have brought up over the time I've been using Vectorstyler. What I appreciate most is the way the developer, @VectorStyler truly listens to the ideas presented and considers their implementation as well as fast turnaround on bug reports and the like.
  • Click on layer widget should not active layers rename
    @mtinra Yes, there is a small bug here when, clicking on the layer name after clicking away should not start editing. The way it was intended is that if the layer name is clicked again (not yet a double click) then it should open for editing. This will be fixed ASAP. As for the double click editing: that can be enabled using the Layer panel menu Panel Options command, with the Double Click Renames checkbox (bottom-right).
  • Wrong object position when pasting on new layer
    @b77 for me if I put back the old files, it go wrong again. It may has somthing else on my machine to trigger the problem
  • Question about saving symbols
    @visualrevolt said in Question about saving symbols: I would like to see something similar to AD. When you drag and drop symbol it stays in the library. These are called presets in VectorStyler. You can create a symbol preset using the Presets panel. And these will be available in other documents also.
  • Questions about creating and using a new color palette
    @VectorStyler thank you for the guidance will follow your advice
  • Live paint/shape paint
    @Sarah-Austen said in Live paint/shape paint: @Subpath any news/progress on the bug? these are questions for @VectorStyler (he already answered ) I am just a normal user like you
  • Printing paper orientation
    @Harry This seems to be a bug, added it to the backlog.
  • Clarifying settings
    @Boldline said in Clarifying settings: There's also a setting on that sets my rotation of an object to designated amounts. it feels like the snapping it on but it's not... If I take an object and grab a corner with the transform tool and try to rotate it, it's not a smooth rotation. I hope that makes sense Is it Prefs > Editing Options 1 > Angle Constraint? This value is for rotating with Shift.
  • Repeater : what do I do wrong ?
    51
    124k Views
    @VectorStyler as I found it easier to define a symbol through the Symbol panel, I understand why I could rarely get the expected results... a somewhat tricky bug [image: 1676979766796-95ee532b-7cdf-40c5-81c5-1191fa52985b-image-resized.png]
  • Align Object Size command is also moving the objects
    @Raven Added this to the backlog. Looks the there is a problem with the scaling center.
  • Problem Viewing or Setting UISTYLER MODE To Light Mode
    @VectorStyler i do not use a high DPI screen therefore I have never heard of such a possibility but will have a look around
  • How to turn off default grid on new projects
    @Boldline That document settings changes the grid color only. Currently, the grid visibility is not persistent to the next new document, but it has been in the past. Which means, that a visible Grid mode is stored in the settings.xml files and it is always on. The only way to turn it off for default is to start with the new settings file (or remove from an existing one, but there is no UI for that).
    27k Views
    @William-Kansepa Thanks. Maybe 'Embed Linked File' is the right word for this instead of 'Expand'. Besides that, it should help both AI and AD users make the connection. (I'm also not sure the Styles menu is the right location for it)
  • Object counter tool tip not showing in last two builds
    @b77 I set the workspace back to the default and the selection counter resumed working properly. I'll send you the workspace file @VectorStyler
  • Moving Text Frames
    @Igull The problem can be replicated. It is caused by the corner handles that were enabled for the transform tool. Will be fixed.
  • "xml:" is missing before name attribute in SVG-File
    @VectorStyler , thanks
  • Support for webp images
  • Corner styles for selected nodes
    @Raven There seems to be a bug here with the selection of corner styles. I added this to the backlog.
  • "Contour" panel
    @Pat The fix will be in the build, it was a minor regression.
    @Boldline said in Using gradient in stroke does not allow for copy and paste or other adjustments: Removing the customized preferences file did solve the issue Send me the custom pref file if this issue occurs again. It might be some settings that causes this.
