• Curve/line & "break apart"
  • Number of blended object limited to 256 ?
    @Pat Yes, it is an (internal) configuration value. Will be increased.
  • Image as fill in appearance
    @Jayanta-Das It is possible to make a tiling pattern from an image. And to use it as a fill (clipped into a shape) with no styling, just apply the image on the object using the Links panel.
  • Locked layer: not totally locked ?
    @VectorStyler I've sent you the file.
  • Is there a CJK vertical text function?
    @Huangzhi More on this in the documentation: https://www.vectorstyler.com/documentation/text/cjk/ A text frame can be drawn as vertical (with the vertical text tools), or turned into vertical.
  • How do I regain the ability to move text on a path?
    @Boldline said in How do I regain the ability to move text on a path?: Is the expectation that someone would turn that preference on if they never had to adjust text on a path or flip it? I think the text on path tool should not select the anchor (shape) if this is on. But it could be a bug here.
  • Duplicated text behave as locked object ?
    @VectorStyler File sent.
  • Easily split a line into two differently configurable parts
    @VectorStyler Thanks, works perfectly well
  • Constrained Lines Question
    @VectorStyler said in Constrained Lines Question: @Igull Is the Smooth Nodes enabled in the context panel? Ahh - nailed it, thanks I was looking for something in the context panel, but that doesn't show until after you have started drawing - it might be better if the trigger for that happened when the pen is selected ? Maybe there's some other reason that I don't know about of course There is also no inferencing (to other points of the polygon) shown, I'm wondering if that is part of a snapping option ?? Neil
    @VectorStyler and yes, I wanted to move objects from a layer to another one.
  • Document in "mm" & text in "mm"
    @PatrickM said in Document in "mm" & text in "mm": Also, how can I adjust the frame to the text? No such option in VS, for now.
  • Snapping: how to get this...
  • Spanish Version
    @formulalatino I added this to the backlog. Will try to have translation by version 2.
    @Boldline said in editing the handles only of multiple nodes at same time - but not moving the nodes as well: pick certain preferences options and customize them in a dropdown folder Maybe in the future.
  • Deciding what part of separated path to keep and what to delete
    @Boldline When deleting a node, it will delete the segment before the node along the path direction.
    @VectorStyler said in How do I commit to changes made with warp tool and retain stroke attributes?: To get back to editing nodes, you need to convert to curves (again). thank you - I found where I got stuck. If the node editing tool is selected and used to select the warped shape, then pressing "convert to curves" will not work - you need to switch to the transform tool and then try "convert to curves" to have success
  • How could i switch off the " X " sign
    @VectorStyler thanks
    @Boldline A possibly fast solution is to just select an object that has an uniform width stroke, then drawing with the Pen tool after that should revert to that width (or to 1 pt width if the previous object has no stroke).
  • Selection Confusion
    @VectorStyler No, the cursor is a small curve with circle on top plus a mini regular cursor LOL. I've tried a vid, but it's not capturing the above cursor change for some reason. The cursor changes from a regular cursor when hovering, to this other cursor when shift is depressed. Neil [image: 1667833913633-screenshot-2022-11-07-at-10.52.38-resized.png]
  • Setting the unit of measurement in the export panel
