      Paste --> Paste in place -... : why in "Placing"?
      @VectorStyler Ok but why not create a submenu in "Paste" for all "Paste..." instead of having it in "Placing", it's just that I expect to find all the "Paste 'something' " in the same submenu of the "Paste" menu... not a big deal anyway.
      Testing Create adjustment layer: some effects apply to all objects (not only the selected one)
      I'm not sure, but I think the adjustment layers with effects is not a feature of other vector apps, but it does exist in Photoshop. It's awesome that we have adjustment layers in a vector graphics app.
      After Boolean Intersect, no more objects
      @VectorStyler In fact, "intersection" works if I merge the two letters first. I can't keep them separated in two distinct layers. Nice ! [image: 1668668348315-618bef82-73b7-4127-91d1-cf0a1efe32a3-image.png]
      Blending: how to get a specific path & not another ?
      @Pat Like your "VS" too very creative
      Could/should the path stroke width be displayed when the path is selected with the node editing tool?
      @Boldline In the context panel? I think it could be displayed. EDIT: but then there are the other attributes, like color, etc.
      Curve/line & "break apart"
      Number of blended object limited to 256 ?
      @Pat Yes, it is an (internal) configuration value. Will be increased.
      Image as fill in appearance
      @Jayanta-Das It is possible to make a tiling pattern from an image. And to use it as a fill (clipped into a shape) with no styling, just apply the image on the object using the Links panel.
      Locked layer: not totally locked ?
      @VectorStyler I've sent you the file.
      Is there a CJK vertical text function?
      @Huangzhi More on this in the documentation: https://www.vectorstyler.com/documentation/text/cjk/ A text frame can be drawn as vertical (with the vertical text tools), or turned into vertical.
      How do I regain the ability to move text on a path?
      @Boldline said in How do I regain the ability to move text on a path?: Is the expectation that someone would turn that preference on if they never had to adjust text on a path or flip it? I think the text on path tool should not select the anchor (shape) if this is on. But it could be a bug here.
      Duplicated text behave as locked object ?
      @VectorStyler File sent.
      Easily split a line into two differently configurable parts
      @VectorStyler Thanks, works perfectly well
    • IgullI
      Constrained Lines Question
      @VectorStyler said in Constrained Lines Question: @Igull Is the Smooth Nodes enabled in the context panel? Ahh - nailed it, thanks I was looking for something in the context panel, but that doesn't show until after you have started drawing - it might be better if the trigger for that happened when the pen is selected ? Maybe there's some other reason that I don't know about of course There is also no inferencing (to other points of the polygon) shown, I'm wondering if that is part of a snapping option ?? Neil
      How to move several objects in once in the layer panel from a layer to another?
      @VectorStyler and yes, I wanted to move objects from a layer to another one.
      Document in "mm" & text in "mm"
      @PatrickM said in Document in "mm" & text in "mm": Also, how can I adjust the frame to the text? No such option in VS, for now.
      Snapping: how to get this...
      Spanish Version
      @formulalatino I added this to the backlog. Will try to have translation by version 2.
      editing the handles only of multiple nodes at same time - but not moving the nodes as well
      @Boldline said in editing the handles only of multiple nodes at same time - but not moving the nodes as well: pick certain preferences options and customize them in a dropdown folder Maybe in the future.
      Deciding what part of separated path to keep and what to delete
      @Boldline When deleting a node, it will delete the segment before the node along the path direction.
