    @Victor-Vector said in Second tap of delete key on a node selected with node editor tool deletes entire shape, not just selected path: You would also like the clicking of a single node and pressing delete twice to delete all the contiguous nodes. Understood! I wasn't too subtle was I? lol Please know that as I am sharing my points and asking questions, I am also open to better options - it helps to talk these things out. We might be splitting hairs - we essentially want the same things and I also defer to what @vectoradmin ultimately decides. I appreciate you breaking down the two main options into counted steps. Here are just some thoughts as I think those steps through. In the modifier example, often the user would be going from section to section with the node tool already engaged and just selecting items with it - if they want to do more than just remove a node, they have to remember to use the modifier key when they click. using the other method, they can decide after selection of the node, whether they want to just delete it, delete the entire subpath or alter the subpath. For me I would favor an option where I tap the same key twice - much like we do now with the node properties - pressing L once gives us a cusp node, clicking L a second time retracts all handles. that feels like less thought is required to act - so personally it feels like less of an "extra step" One of my goals is to try to re-use modifiers in any way possible so to preserve them for future features not yet implemented. I also prefer having the ability to edit a selected node and not have to think ahead of time if it's going to be edited do this and if it's just deleted, do that. You make great points and I'm sure the end result will be awesome, whatever @vectoradmin decides would fit best in the program
  • How do I selectively edit the height of some of the text on a path?
    @b77 .... converting the text to curves is not needed ... Thanks, I already know that. Have been experimenting around with Envelope Shape and others lately. Will post the findings in the tutorial or general section (not sure where yet) in the near future. .... converting the text to curves is not needed ... but could possibly be better in some circumstances for a smoother shape/curve progression
  • Hiding nodes when selecting a group
    @b77 said in Hiding nodes when selecting a group: @Ingolf If I understand correctly, you just need to disable 'Show Nodes of Selected Shapes' in Preferences > Editing Options. Bingo - thanks! [image: 1648767970588-8022fd34-9998-4764-9909-3501871c1455-image.png]
  • How do I change the UI color of the editing curves?
    @Raaskot , ok
  • Forcing translate transform shape effect?
    @Nils said in Forcing translate transform shape effect?: @vectoradmin Nice to hear that. When's the next bugfix build to be expected? I think you said end of week or something right? If all goes well the current batch of fixes should be in a build by Monday afternoon (Finland time).
  • A problem with opening files via File Explorer in Windows 10
    @encart I will try to replicate this, added it to the backlog.
  • Default drawing mode
    @vectoradmin said in Default drawing mode: @Ingolf I think the solution for this is to keep the last selected drawing mode persistent. I added this to the backlog. EDIT: this means there is no need for new settings. For me, that will suffice.
  • Actual size: VS don’t display artboard/canvas in 100%
    Its non-retina: [image: 1648626397079-591843a9-3f85-4ea9-819f-9aa66ba4ebb5-billede.png]
  • Guide Shapes: Is there a place to save them as Guides?
    @Victor-Vector Very cool idea to make guide shapes like that for future use - nice job!
    @Boldline Well, this is the same for most of the other features of VS. There are panels that contain (mostly) a subset of options and then each such feature may have a larger (more complicated) modal view. I think panels are useful, to allow non-modal editing of selected parameters. And it is not possible to publish all options in panels only, so modal views are also needed.
  • Pattern Brush - Do corner options exist in VS?
    I really miss these options as well this makes beautiful patterns possible. Like here, only one oversized stroke on a Star. [image: 1648535884757-big-stroke-1.png] [image: 1648535890636-big-stroke-2.png]
  • Copy-paste/sync node angle/tangent
    @vectoradmin Oh, right. Yes, so we can avoid clutter in the UI and just add a sentence in the documentation. Elegant.
  • Panels Opened on Startup
    @Sullyman I think this is part a bug, part missing feature. The (minified) panel states should be restored at startup, if not this is a bug. Having a toolbar-style arrangement of minified panels is not possible now, this is in the feature request list, has been requested before. One thing that is possible now, and could be close to this, is to create a new custom toolbox (Customize Toolboxes) and add the panel opening actions to that. This will temporarily pop-up the panel, but it will also close when clicking away.
  • Resizing Floating Panels - Cursor Outside vs. Inside feedback
    @Victor-Vector This looks like a bug, as it should not depend from which side the mouse approaches. I just checked, and the same issue happens on Windows 10 also.
  • Sliders and Color Wheels
    @Petar_MK Initially I was a bit thrown by this too, but then I came to realize it had advantages to be able to set them separately. For instance I like to work with an HSB wheel for the visual feedback of the wheel, but sometimes I will want to see RGB values to my corresponding choices. I certainly has helped me understand the relationships between the different color system representations. I suppose it's easy to set if you want them the same, and there are only 4 that correspond between 18 the sliders and wheel/spectrums.
    Cool! Thanks:-)
  • Can strokes with width adjustments be blended?
    @Boldline I think the issue is that these two shapes contain brushes, and it seems that the brush content is not blended.
  • change brush with either the transform or the shape editor tool?
    @Boldline This looks like a bug. The brush list is a preset panel, are you doing double clicks on the brushes in the list? One thing to try is to enable "Apply on Selection" in the panel menu, to use single clicks to apply the presets. It should work in node tool also.
  • Can SHIFT + Arrow Key movement increment be adjusted?
    @Victor-Vector I add this to the backlog, it is not a hard thing to do.
    @Boldline Or just Shift+click on the control nodes.
