      Double clicking selected object query
      Thanks for the info, that's clever. I'm going to use that a lot now! [image: 1632825895625-screenshot-2021-09-28-at-11.40.53.png]
      New user, i stuck with a simple thing
      27
      49k Views
      @vectoradmin , thanks a lot already downloaded
      Drag panel from any part of top bar
      Collapsed panels stay collapsed when moved around inside VS
      @Boldline This is in the backlog.
      Gradient Mask Editor - Reverse The Transparency Points
      Thank you.
      value of even-odd fill/winding fill
      @Boldline AI also has this but I think the default there is Winding. Once the winding fill mode is set for a shape (Appearance panel, or Object -> Content -> Winding Fill), the new shapes will be drawn with it. I think there could be a preferences for having it on by default.
      Controlling nodes and handles when deleting nodes to fill in a gap
      @Boldline There is an option: Prferences -> Editing Options -> Adjust Node Removal Curvature, that will not approximate the original curve when removing a node.
      Clicking on gradient bar with shape selected transfers gradient settings to shape
      @Boldline Can be implemented, added to the backlog. Attached the file here: gradientidea1.vstyler
      Alt/option key + click and drag creates new gradient color stop
      Stray gradient presets outside their folder?
      @Boldline When creating new presets, these are added to the root of the group (specific to the preset type). The Panels -> Presets -> Presets panel, or the Styles -> Preset Manager view can be used to place these into folders, or to create new folders.
      Remove gradient point
      Thank you.
      Do not auto-open duplicated layers
      @Boldline This can be replicated, added it to the backlog.
      Show selection with transform tool/etc
      @Boldline If I understand correctly, I think you need to enable 'Show Nodes of Selected Shapes' in Preferences > Editing Options.
      Just like to mention, VS Price tag was absolutely ok for me
      New user, must say how deeply impressed I am
      @Subpath2 Thanks!
      Can we import Affinity Designer brushes?
      Hi @Boldline The Reason while you can not import Affinity Designer Brushes may also be , that only one Brush in Affinity Designer is a real Vector Brush. The others are Bitmaps along a Vector Path.
      How do I get text to fill an existing shape?
      18k Views
      @vectoradmin i just sent you the file and an explanation. Basically the left side of the sunglasses were initially a copy and flip of the right side. So everything on the left side will be in reverse I assume - based on other discussions in the forum about that. Maybe the solution here is I need to flip the path direction?
      Image trace number of colors slider
      @Boldline @b77 added to the backlog!
      How to change layer name without opeing layer panel?
      @vectoradmin I'm using only mouse now. In Canvas&Artboard / Styles panel both methods are working - two clicks & Return key. Non of them work in Layers panel. https://recordit.co/nxTCRjltyt
      Convert Photo Image To Vector - White Edge On Each Shape Of The Vector
      @KF Thanks for the image. I tested it, and with anti aliasing turned off (View -> Subpixel -> None) here is what I get: [image: 1632043942031-trace2-resized.png] The anti-aliasing artifact is in the backlog (list of things to fix), and I will try to find a solution for that.
