• Do not auto-open duplicated layers
    @Boldline This can be replicated, added it to the backlog.
  • Show selection with transform tool/etc
    @Boldline If I understand correctly, I think you need to enable 'Show Nodes of Selected Shapes' in Preferences > Editing Options.
  • Just like to mention, VS Price tag was absolutely ok for me
  • New user, must say how deeply impressed I am
    @Subpath2 Thanks!
  • Can we import Affinity Designer brushes?
    Hi @Boldline The Reason while you can not import Affinity Designer Brushes may also be , that only one Brush in Affinity Designer is a real Vector Brush. The others are Bitmaps along a Vector Path.
  • How do I get text to fill an existing shape?
    18k Views
    @vectoradmin i just sent you the file and an explanation. Basically the left side of the sunglasses were initially a copy and flip of the right side. So everything on the left side will be in reverse I assume - based on other discussions in the forum about that. Maybe the solution here is I need to flip the path direction?
  • Image trace number of colors slider
    @Boldline @b77 added to the backlog!
  • How to change layer name without opeing layer panel?
    @vectoradmin I'm using only mouse now. In Canvas&Artboard / Styles panel both methods are working - two clicks & Return key. Non of them work in Layers panel. https://recordit.co/nxTCRjltyt
  • Convert Photo Image To Vector - White Edge On Each Shape Of The Vector
    @KF Thanks for the image. I tested it, and with anti aliasing turned off (View -> Subpixel -> None) here is what I get: [image: 1632043942031-trace2-resized.png] The anti-aliasing artifact is in the backlog (list of things to fix), and I will try to find a solution for that.
  • Pencil line colour question
    @vectoradmin Thank you that's brilliant. @Boldline Thank you, that's a great tip.
    @encart For this, you must align to a key object, and specify the key object by clicking: steps from the video: https://recordit.co/R83pZ7gBOA select the objects select key object mode (second in the left group at the panel bottom). click on the key object, in this case object 3 on your picture. click the alignment buttons.
  • Copy attributes
    @Boldline There is no eyedropper tool for character style, but the Copy / Paste Character Style in the Edit -> Attributes menu should help with this. For other attributes (like fill, outline, etc) the eyedropper tool should work.
  • Toggling pressure setting for eraser brush
    @vectoradmin Wow! I love it! I was not even thinking about an eraser options panel pop up - I love the control and settings it has. thank you
  • Constrain VS to Available screen space?
    @Boldline This probably works only on the Mac, but horizontal swiping while hovering over the context panel should scroll the content of it.
  • 1.0.047 Custom Character Styles disappear when you exit VS
    @encart Character styles are stored in the document. There are multiple ways to reuse character styles between documents: create and use a document template containing the styles. export the character styles to a file and import into another document. use character style presets (instead of styles), but these are not linked. link an other document containing the character styles using the Styles -> Document Links command.
  • Vertical Type Options
    @Boldline I will have to find a better default for the "Auto Vertical Roman".
  • Keeping layers closed when editing hierarchy
    @b77 awesome! thank you
  • Trial - Extension?
    I can confirm that performance is far better in the latest version of the app - thanks @vectoradmin Just did a little test on a 1.5m wide banner gradient background… and the responsiveness of the canvas and artboards was great. Brilliant!! Video example
  • Could Stroke panel and Stroke Width Panel be combined?
    @Boldline I'm not sure about this one. The Stroke panel is large as it is. The Stroke Width panel contains options used only when editing the width profiles. But these can be docked into one column.
  • Control-V to paste image copied from web into document
