• Change Text Default Color
    @Boldline If the document is in CMYK color mode, it's best for the text color to default to standard 100K black (C0 M0 Y0 K100), so you only need one plate — the black plate (if it's only text). Otherwise you would get 4 plates just for black text — much higher cost, possibly having to remake the black plate because the text is not at 100% black, and also registration issues nobody needs ("ghosting"). If however you want a darker black for text intended for print, and if that black text sits on some other lighter colored objects, setting the fill of that text to overprint will make it darker because it will be combined with the colors under it.
  • How do I reset panel default shape?
    @Boldline Drag the panel from the title area (that double horizontal line under the close button) to the right (or left) margin, where the blue highlight indicates docking.
  • Distribute but not by hierarchy
    @encart Awesome! Thanks for letting me know. There's a lot I learn on the forum from everyone else asking about things I didn't think or know to ask. I'm glad I was able to help others as I have been helped
  • Pasting new shapes dead center by default
    @b77 Thank you for sharing that - not sure how I missed it but that is really helpful
  • Text Tool and Area Text Tool - Cannot Cut and Paste
    @KF The above steps work here (on Windows). I have to investigate this further. There have been reports of issues with Windows clipboard before.
  • Minimalizable Panel Windows
    @Boldline Thank you, you understood me correctly. That's cool that it's already possible in VS. Kind of a hidden Feature, because there is no visual indicator that this is possible
  • Resolution Matters
    @vectoradmin Thank you for your hard work. Appreciated. Best regards, KF
  • Distributing nodes equally along a line.
    21
    35k Views
    @Jono me too
  • Option to auto close all selected open shapes, etc
    @Boldline In the Path panel, second row third icon should close individual paths without joining them.
  • Any mirror function in VectorStyler ?
    @vectoradmin Thanks for your explanation. Will study it when I have a little more time.
  • Outline stroke
    @b77 said in Outline stroke: @William-Kansepa For what you asked in the original question, use 'Expand Stroke' from the Styles menu. Thank you so much @b77. This is exactly what I was looking for. Thanks to Numeric Path for coming out with an unorthodox program. It definitely keeps us on our toes. After tons of years on an Adobe diet, I am having to unlearn a LOT of things.
  • Can avoid pixelated graphic if export the vector graphic to PNG or JPEG?
    @KF But, if you need vectors after export, use PDF or SVG formats. With some exceptions (image effects), these will have vectors.
  • Delete saved pattern from preset
    @vectoradmin Hello, I have delete the pattern. Thank you for help.
  • Will presets slow down the software loading time and performance
    @KF No need to avoid it just let me know if something slows down, and will treat it as a bug.
  • Bendy Arc warp
    DazmondoD
    For more details on the bendy logo see: https://www.vectorstyler.com/forum/topic/939/bending-logos-accurately-around-a-curve-for-a-vinyl-lp-label
  • Offset command adding too many nodes/anchor points
    @vectoradmin said in Offset command adding too many nodes/anchor points: @William-Kansepa Were these offsets created in a single step (by setting the Steps field to more than 1) or in multiple steps? Sometimes it is better to do in a single step, because then all offsets are created from the outer shape. When the offsets are not uniform (as in the above case), then it is still better to create each from the outer shape, by increasing the Distance value. When an offset is created from an offset, this may result in more nodes than needed. I add this to the backlog as a task to improve repeated offset precision and avoid adding too many nodes (or maybe an option to keep the node count). The nature of the design requires that this be done using single steps to maintain precision.
  • "Align to" Reverts back to Selection Bounding Box each time
    @Boldline That explains why I could not replicate it. I was using the panel (not the popup). Now the root cause is clear, and it will be fixed.
  • Should text layers auto update name if text is altered?
    @Boldline They should auto update. I tried to replicate this, and here the name in layers panel changes with the text (even added some shape effects, to make it the same.)
  • Antivirus Issues?
    @mainstreet1612 I'm glad that all got worked out!
  • What would be the best way to warp several lines at one time?
    @Boldline Hi I would use "Blend" for this and then refine it with the "Corner Editor" Tool This way you would also have better control [image: 1634111740840-blend-1.png] [image: 1634113637211-blend-2.png]
