• Japanese
    40
    99k Views
    @ash-f This issue is still an open bug. Will try to fix as soon as possible.
  • Layer Options Panel - real time opacity preview
    Anyone else remember the Interface Hall of Shame? Evidence that things could be worse: http://hallofshame.gp.co.at/controls.htm#CONTROLS46
  • Pen tool auto-set to fill with no stroke
    @Kyriakos @Kyriakos said in Pen tool auto-set to fill with no stroke: respect the selected colour and fill rather than drawing every new pen shape with stroke and no fill I agree with you on this - I would prefer each document open with black stroke no fill for the pen tool default, but as soon as you change the stroke and fill settings, they get used on every future pen tool use or rectangle or circle shape, etc... going forward until it is changed again by the user
  • Question about Repeat Last
    Hi, That works, thanks.
    @vectoradmin said in Possible Bug in Context Panel for Fill and Stroke, plus related questions?: @Vector-Rock The no fill selection from the popover fill palette list is fixed in 1.0.025 Thanks, working properly now!
  • Options in Snapping Panel. (Windows)
    @Gremriel Got it. Thanks! The bug also occurs on Mac.
  • Preview Shape Combine (Document Editor option)
    @Gremriel Looks like an error. Will be fixed in the next build. Posting is welcome this is how the app gets improved.
  • Regarding Guidelines
    @Gremriel Yep, got it replicated. Problem occurs after multiple documents are opened, and switched between.
  • Text on Path: how to make the text centered?
    Thank you.
  • Mysterious guide
    @vectoradmin Nice!
  • Text on Path: what is happening here?
    @Gremriel The selected text outline issue is fixed in build 1.0.025. Let me know if there are other issues.
  • Info panel with object (segment, node, etc.) information?
    @Arde Yes, that is the document info, and it does not show info on objects. I think a separate object info panel (with position, size, colors, and maybe shape length / area) could be added at some point. I will add this to the new features backlog, it might not make it into version 1.
  • "Japanese vertical type" 2
    @861475_VctSt Let me know what are the issues
  • Origin of artboard
    @vectoradmin I confirmed the correction.
  • What does isolation mode of single element do?
    It's like the mask workflow in FreeHand, instead of using clipping masks a shape can be masked by copying it and using "Paste Inside" in a parent object. Then once you double click the parent object and enter isolation mode you are able to edit the contents you just pasted in. You can also repeat the process on the children objects and paste things inside of those to create masks inside of masks. It confused me too at first because i wasn't expecting it and the relevant UI was pointing me towards something like Illustrator but It's much faster and intuitive method than clipping masks, trust me on this.
  • Is there a way to specify overprint attribute for a color?
    @vectoradmin said in Is there a way to specify overprint attribute for a color?: This can be done in the Styles -> Overprint Options -> menus. Ok, thanks. Did not quite follow but I'll try to figure out how this combines with the separations printing!
    @vectoradmin said in Is there a way to flatten blend groups and similar controlled constructions?: The new build adds a separate "Position" function to the blend object transfer curve options. This will control the position of the inner objects. Brilliant! It is very rewarding to give feedback when suggestions and reported bugs are clearly noted and reach immediately developers!
  • Possible release date?
    @vectoradmin ok I'll try to do more with those areas you highlighted, you know you can count on me to give you the older el capitan reports!
    @vectoradmin I checked the "color profile" display. A small but very useful feature for us. Thanks
  • Convert path/curve to text frame?
    @b77 I will look more into how to merge these two tools.
