• What is "stroke"> [fill] ..... ??
    @vectoradmin Completely remove VS (by AppCleaner) Not an overwrite update, I reinstalled it. As a result, it was fixed. Thanks It's getting more and more comfortable.
  • Patterns
    syllieS
    @vectoradmin said in Patterns: For now the outline can be selected in the panel, by changing the panel state with the up-down arrow before the panel title label. This rotates over several panel modes, the second mode contains the outline and background setting. Ah! I know about the states, just didnt think to check it here! Thanks. All the other feedback makes sense too!
  • Anyway to dynamically change the 'brush' size?
    19k Views
    Seems to be working with the pencil and brush now on the Mac also.
  • Logic behind node controls
    @grix An explanation of how nodes work in VS: There are two concepts to define first: the node is a point location. the segment goes between two nodes. The type of a node can be cusp, smooth or symmetric. This affects how the curve changes when the node is edited. Changing the node type from smooth (or symmetric) to cusp will not have a visible effect, since the two control points (on the two sides of the node) are not changed. The node type is only visible when the control points are moved. In cusp nodes the two control points around the node can be moved independently of each other. In smooth nodes, the distance of the two control points from the node is idependent, but the direction along the same line (creating a smooth curvature). In symmetric nodes, both the distance and the direction are constrained. (Most apps don't implement symmetric nodes, except CorelDraw). The type of a segment can be line, quadratic and cubic. Typically we have lines and cubic curves. VS includes quadratic also, these are the curve types used in TTF font glyphs, and also required for SVG. The difference between quadratic and cubic is the number of control points (and degree of freedom) on the curve. Most apps don't have the quadratic mode. The change that you were looking for (removing the control points) can be found in the Path panel, with the first two icons in the third row. These change the node type to cusp, and move the incoming / outgoing control point over to the node location.
  • Sometimes Control-A then delete only deletes last object selected
    @Boldline The select all problem (while in drawing mode) is fixed in the new build.
  • How do I revert back to initial traditional star shape?
    @vectoradmin The star shape reverting and other issues are fixed in the new build.
  • How to start drawing a new shape with the pen tool next to another
    @vectoradmin Snap to point and snap to shape combination has been improved in the new build.
  • pen tool drawing guide toggle
    The current snap red X indicator also causes a small delay in the process of going on to the next task - the next node, etc.
  • Things that still keep me from using VS for all vector drawing
    Yeah, it is really strange, I hope you find what causes it, thanks @vectoradmin !
  • Last stroke of pen tool affects first line
    @vectoradmin Great! I will test it out and get back to you
  • Layers Panel - Highlight vs Select
    syllieS
    @syllie I just found it is actually documented - just not where I expected it: Selecting from the Layers panel. Maybe a link to that section is warranted in the description of the layers panel.
  • Font and interface sharpness
    Also great
  • Bitdefender gives (false) alarm on VectorStyler.exe
    @Arde What is the message given by Bitdefender?
  • Brush keeps returning to default size
    Just tried it, much improved thank you!
  • Can nodes be set to smooth by default instead of symmeteric?
    @Boldline "Fixed: Exclude created a smooth node at a cusp node" is a different fix to a bug I reported, involving the Exclude boolean operation.
  • Getting small questions answered
    @vectoradmin You're doing great! I just feel bad taking you away from other important things to answer my questions on basics. I promise I do try to always look things up myself before asking. Sometimes I wonder if I'm looking up the right terminology or if it's not been added to the app yet, or if there's another option that might be better than the solution I'm used to thinking based on previous apps. i do appreciate you answering the questions because it means I can keep practicing with VS on real work
  • Edit node and arrow size preference
    @vectoradmin thanks - I saw that option in there and wondered if it was what i was looking for - thanks for confirming
  • Arrow keys move selection box, not fill
    @vectoradmin Yes, I figured that out, thanks!
