    3. VectorStyler 1.2 beta
      Path Dash, Stripe and Profile not highlighted in blue in Stroke panel
      I personally prefer highlighted values
      How do I get rid of strokes on traced and exported images?
      @Harry I misunderstood, thinking the issue is strictly related to export (the settings I suggested are found in the Export window).
      Create divide between "Drawing Place" Icon and "Snapping Tools" icons
      How do I hade the outline around the clipped composite shape?
      @Boldline I don't get this outline in the example file emailed earlier. What is the active tool when this outline is shown?
      Why does the background change color and give a flash effect each time a node is moved or edited inside a clipping group isolation?
      How do I edit an isolated shape inside clipping mask?
      @VectorStyler said in How do I edit an isolated shape inside clipping mask?: Isolating and Node tool should work. ok I got it to happen again where it dialed down to a specific path. At that level, literally no tool will function.
    • VectorStylerV
      beta 1.2.013
      7 Votes
      @Pat You need to download and install manually, the version was not incremented for this fix.
      Customization, application menu
      @VectorStyler @b77 Thank you, my double click was too fast. Got it now
      Appearance panel "FX"
      is the third icon from the left [image: 1708155550557-shape-effect.png]
      Double tapping the "L" key often switches to the Path Sketch tool
      @VectorStyler sent the files...but realized it may have just needed a reboot of VS (it had been open for a day) because now it's working fine with both the default and the custom settings installed. I'll let you know if it comes up again.
      Path Brush option to toggle rope option not visible to me on 16 inch mac laptop
      @VectorStyler ok that makes sense and that worked. thank you
      Add an option in "Document Setup" to save current configuration as a new template option?
      @VectorStyler said in [Add an option in "Document Setup" to save current configuration as a new template option?] Some of these features are a combination of several options and maybe not well documented. It's not for me to say , but the lack of case studies makes it difficult for me (perhaps others) to read the documentation. It would be good to include an example of the various aspects of using VS and its multiple options, such as the uses of the document setup options, the use of guides/grids options, of different canvas (reference and others... still to be studied), etc. In my humble opinion, this would help some users to master the various options and use VS by default
      Scaling up or down live text feels very jumpy
      @Boldline I opened a bug on this one.
      Add "Duplicate" function to Right-Click menu options in New Document Setup"
      @Boldline I will add the preset saving option to the New Document Setup view also.
      Link to Preset Manager from New Document Setup Panel?
      @Boldline Scroll down on the right side and there is a more options button.
      Adjusting a text frame to fit the text
      @861475_VctSt I added these to the task.
    • AyoA
      Simplifying gridded color palette separator?
      @Ayo I added this to the backlog.
      Snapping descriptors are not in plain speak in version 1.2011
      @Boldline @b77 Fix is available now.
    • VectorStylerV
      beta 1.2.011
      8 Votes
      I uploaded a fix with the text resources issue.
      Paragraph style - can't be changed through the panel
      49
      113k Views
      @Pat said in Paragraph style - can't be changed through the panel: when I create a new style and the cursor remains on the modified text from which I created it, this specific new style is never selected in the styles panel but always the previous style with the "+" sign This is by design. Creating a style (in general) from a selection does not automatically apply that style.
