• Is it possible to load hex codes as a color palette
    @VectorStyler Thanks, no action required. I just wanted to know.
  • Spiral Polygon
    @monsterfox yes it is better, I will add this to the backlog of features, to improve the polygonal spiral
  • how to exporting selected layer slices ?
    @lilith Not possible. In VectorStyler slices are markers of areas of the canvas to be exported. So this will cover any layer that intersects with the slice area. Maybe what you need in this case is the Object Export feature, where you can mark objects using the Object Export panel (Panels -> Editing) and then export these.
  • Loading a color palette doesn't work as expected
    @VectorStyler thanks, would be helpful
  • Type 1 (PostScript) fonts in VectorStyler on Mac
    @Buntstift I opened a bug on this. You can also try to add the Type 1 font into the internal font manager of VectorStyler (Text -> Font Manager).
  • (Artistic) Text tool
    @FastVector said in (Artistic) Text tool: But is it than still possible to get frame text or do you first have to uncheck this in the settings? I will try to find out the issue here.
  • File currently being used
    @monsterfox Actually, the replacing of an opened file is a feature. One can change the file form some other tool and if the file was not modified in VS, it will be automatically updated when VS gets to foreground. (BTW: you can save a VS file into JSON or XML format, and edit it with a text editor , and if the file is open in VS it is automatically updated ) I will have to check the delete part.
  • How to paste vector objects from VS to Inkscape/Cavalry?
    @Harry said in How to paste vector objects from VS to Inkscape/Cavalry?: I hope VS can do it someday! I will try to add this ASAP.
  • Just out of curiosity
    @VectorStyler Thrilled to hear 80% of the features will land in v1.3
  • Non Desctructive
    @VectorStyler interesting and pretty cool
  • Question about using Paths with Composite Shape Boolean
    @VectorStyler said in Question about using Paths with Composite Shape Boolean: First create group from the 4 lines. Thanks! Seems that this was the solution, to group the paths first and then applying the composite shape mode. Its working so far. Made a Video for everyone who is interested. To create a "normal" Shape from that use "Expand Appearance" Here the Video which shows the Steps
  • Node Switching with keyboard Y/U works fine, L needs 2 presses?
    @Ayo said in Node Switching with keyboard Y/U works fine, L needs 2 presses?: Why does retract the handle (L) not work for the starting node? Seems to be a bug.
  • Would like to Skip that import dialog panel
    @VectorStyler said in Would like to Skip that import dialog panel: Also, maybe an option to skip if importing a single canvas file? I mainly import single canvas files, so this would be a great help
  • Does vectorstyler run on the actual m4 ipadpro ?
    @Honor There is intention and plan, but it cannot happen before 1.3 is out.
  • Presets working the wrong way
    Thank you very much! The new version has finally fixed everything. This is a feature I would have wanted from day one. Now the workflow will definitely speed up! Thank you again.
  • Curves on blending objects on a rounded shape not working?
    @pilkafa I will test if the "Common" curve should also affect the position, but in the meanwhile use the "Position" curve
  • separate paths
    @VectorStyler ![0_1743155557078_2.jpg](正在上传 100%) [image: 1743155633044-2-resized.jpg] The entire file is ready—you can directly copy everything to VS. However, the red and white (paths/elements) will break/disconnect.
  • Same width, visual difference
    @fdarnel I got the file, this is the same bug as I mentioned earlier with the UI display of stroke width. The fix will be in the next build
  • Found a blend feature that no longer works?
    @VectorStyler Since I found this by chance, I wasn't aware that it is related to the Blend Tool. Therefore, I thought it was a general feature of a Blend or smooth. But now i know how it works, thanks.
  • One panel always opens on secondary screen - how do I change this?
    @VectorStyler ok moving it back to the main screen and then closing the panel and reopening it worked.
