• How do I remove a brush from the brush preset list?
    @Raaskot said in How do I remove a brush from the brush preset list?: For my part the Brush Presets list is empty. How comes? This may depend on the current workspace state, there can be multiple brush presets panels and some may end up empty of the associated group is removed. Is there a "Reveal Hidden Presets" in the panel menu? If so, select it. Otherwise, see what panel gets opened with the Panels -> Presets -> Brush Presets command.
  • 1.2.074 updated and File menu broken
    @VectorStyler Excellent, thanks! I'll try to remember to search first next time
    @Boldline The history of changes made before turning the option on might be lost.
  • Blended Shapes : how does it work ?
    @EricP I opened a bug on this and will try to replicate it.
  • Stroke blending
    @VectorStyler thank you for the fast turnaround in fixing this bug
  • Eraser setting altered the way eraser works - deletes whole objects now
    @VectorStyler it was at "0" ok that explains it. When I make it any other size, it returns to the right functionality. Ironically, I can see that being a useful option on occasion - the ability to click or drag on the shape and the whole thing erases immediately. Thanks for your help!
  • I notice two problems while editing pattern brush settings
    @Subpath I opened a bug on this. The checkbox sizes sometimes are extended to leave room for translations. This can be fixed of course.
  • Three improvement points
    @VectorStyler The key point is that sometimes when operating a graphic at a certain level in a group, after completion, due to too many layers, I can't remember how many layers there are. I don't think anyone pays attention to this. Originally, I need to select the final parent level of this group, so I keep pressing shortcut keys until I select the group. But now the problem is that all layers will be selected, which is always uncomfortable in operation. It requires the operator to be careful, but operational errors cannot be completely avoided. So I still hope to solve this problem. Thank you.
  • How to crop a vector design ?
    @EricP said in How to crop a vector design ?: is it a ratio between height and width of the shape ? Yes, something like this. I often end up ungrouping them for the sake of the selection but there may be a better way. I'v Double click the group and that will isolate for selection.
  • Starry night : is there a way to achieve this with VS ?
    22
    20k Views
    @Li-Xiao 这个操作真的很新奇,好像管理员都没有想到。这个功能我是基本用不上了。工作中没有太适合的场景。现在依然觉得论坛里你玩VS最溜。
  • Find/Replace Question
    @VectorStyler said in Find/Replace Question: Why not replace just the shape. Draw the new tile shape in one object, copy the shape to the clipboard and paste on multiple other objects. This will keep all local skew, rotation, scale of those other objects. And then do this for the color / style of that changes. I just tried with a single shape - Paste Shape didn’t preserve rotation, etc.? Anyway, neither roof tiles, leaves, bricks, nor windows I make are single shapes - they’re objects with embedded details, essentially groups of objects. There’s quite a bit of work behind the details in them. All the things that make the illustrations feel organic and less like clipart. But as mentioned, probably not a typical use case.
  • open recent Help
    @VectorStyler Thank you, everything is working!! thank you
  • Setting a fixed rotation angle for multiple shapes
    @EricP said in Setting a fixed rotation angle for multiple shapes: I see that I can just remove the transform effect from the shape effect list for the selected objects Yes, the Shape Effects panel can be used to manage shape effects of an object.
  • How would I remove an item from a selection?
    @VectorStyler yes
    @VectorStyler thank you. That's exactly what I was looking for. So many hidden capabilities to discover. what's the purpose of the repeater icon 'check to apply shape effects to the repeater content' ?
  • Scaling with "for each" in Transform panel works way too hefty.
    yes I observed the same and found it excessive too. I think the scaling randomization picks a random value between 0 and 100.5%, which yields to extreme variation. Offset and rotation being in absolute values - not percent, the effect is easier to adjust precisely With only one cursor for scaling, maybe the variation in that case should be +/- 0.5% (99.5% to 100.5%) to remain more subtle.
  • Clipboard
    FreeHand 9 apparently copies to the clipboard in the following formats: WMF, EMF, PICT (Mac only, DIB/Bitmap, FreeHand internal format You can reportedly copy in these formats via Copy Special: EPS, Adobe Illustrator 7/8, Bitmap, Text It seems the clipboard isn't well suited for use with Freehand and VectorStyler plus other modern tools, unfortunately.
  • Am I not able to select by same name?
    Smart! Of course! Thanks!
  • Arrange toolbars horizontally
    @VectorStyler Thanks. I'll look into it later.
  • Text Frame gets added accidentally when editing offset path result
    @VectorStyler That makes sense. Thank you for checking into that for me. I'll have to remember to always click on the top menu bar area to detach from the color palette before copying and pasting
