• Shape Builder or Paint Tool integral approach
    @Ayo said in Shape Builder or Paint Tool integral approach: Here you see the miracle happen: https://recordit.co/0bc8r77OyW Got it!
  • Why do I lose my text and text frame?
    @Ayo Yes, there was a mixup with text duplication. The fix will be in the next build. The text can be reassigned from the Links panel, by double clicking on the text item.
  • How to assign a blend
    @b77 Very clear and beautiful! but there are more groups than Blend Mode on the menu
    @Ayo said in Feel like a digital dummy working with Vectorstyler or how to ungroup all groups in layer: Here the piece of land cover. Thanks! This will help a lot. I have now a bit of a backlog of fixes to do, but I should get to this soon
  • More questions
    @VectorStyler (1) Only a frame indicator is sufficient [image: 1698655672834-0392f7de-737d-4e51-9020-49bc1fb11b84-image.png] (2) I understand
  • Node selection problem
    @Li-Xiao OK! The 'Shift' does the job also. But I think I prefer "select nodes from all objects". Faster and fewer errors (include previously covered points). Thanks.
  • Snapping panels redundancy
    @b77 In any case, it does not help to solve this location spaghetti tombola [image: 1698579368004-febbe298-7615-4cc0-9af2-7f8ab3242d06-image.png] !
  • Node Tool object selection
    @VectorStyler My wish/goal is to make the Node Editing tool as versatile as possible, resulting in fewer tool changes during editing.
  • Second color selector options
    @Ayo Not possible. The "Edit Color" in the panel menu has such option.
  • How to clear selection while in Node Tool mode?
    @b77 said in How to clear selection while in Node Tool mode?: @VectorStyler I would include this among the default node editing shortcuts, for former CDR users. Will be added.
  • Problem with bending of point/shape text
    @Ayo I opened a bug on this, and will try to fix it.
  • Brush style
    @Kumr Gradient is not supported in vector brush.
  • Christmas tree lighting
    @Ayo said in Christmas tree lighting: @VectorStyler Better! Also with only the Object Snapping Indicator now, again less clutter! The problem arises that you have to keep a logbook or spreadsheet for all the settings and where to find them. how about save snapping presets you could do that and give it a meaningful name
  • "Cut Path at intersections"... what did I do ?
    @VectorStyler I'm sure it's not easy to determine the cause of the problem after the fact. I've been dragging this thing around for weeks/months and I still wonder why the "Cut Path at..." feature solved the problem... well, let's move on
  • Zoom to '100% screen size?
    @VectorStyler First attempt failed Document Setup -> Resolution to 218 (my screen resolution Apple Studio Display) View -> Display Resolution to 218 Result: view much to big After calculating and measuring the ruler screenshots I came to a scaling factor of 33%. 0.33•218 Equals 72! Second attempt fills the bill Document Setup -> No need to change, leave resolution to 300* (default) View -> Display Resolution to 72 *leave resolution to 300 Better not change, right? Isn't this the resolution for rasterizing effects for HR printwork RIP (Raster Image Processor)? [image: 1698239567941-de4c6af7-49e8-45ed-81ed-40710d571a99-image-resized.png] !
    @Boldline Yes, that icon creates a single (new) object that is a blend of two objects. This is a 1.2 feature.
    @Boldline I don't think there's a modifier for that. Press X to switch to Stroke color, then picking the color from the fill of the other object will assign it to the stroke.
  • Baseline grid options
    @VectorStyler Thanks. Will manage with that option.
    @Boldline Path Editor Show Eraser Shape (and Path Brush and Knife),
