• Commit to warp result without merge?
    @VectorStyler ok I'll try that - thank you. I'll also try and replicate the other issue where ungrouping caused the warp to change and record a screen capture
  • Transpose - random proportional scaling work not as expected
    @VectorStyler said in Transpose - random proportional scaling work not as expected: @Subpath Added this to the backlog. Looks like the proportional option is ignored when randomizing scaling. thanks, was also my thought btw is also the case in Object> Transpose > Scale
  • How to get displacement effect?
    @jroth you are welcome, nice that is helpful Boolean combining is exactly the same thing as combining in other vector programs. So it is nothing special. In VS you can find Combine under the Boolean operations. And of course you can also combine strokes
  • Image Not Shown in PDF
    @VectorStyler said in Image Not Shown in PDF: @gotanidea The Precision field (first export view - PDF Options) should be larger than 0, more like 2. (should not allow 0 here, will fix this). I see. Thanks Admin
  • Performance issues with vector editing
    performance
    23k Views
    @Bones Anti-aliasing can be turned off using View -> Subpixel -> None. But it has only a small impact on redraw performance. At what zoom level was this slowdown observed? and is it with the AI import or the SVG (results are different). As for the AI file: some features are not (yet) supported, there will be improvement in the future.
  • Clicking live text with stylus highlights letters
    @Boldline Yes, the Stylus is a bit sensitive to movement. I will try to find a solution for this.
  • Automatically Update Missing Links as in Adobe Illustrator
    @gotanidea said in Automatically Update Missing Links as in Adobe Illustrator: Update Missing Links I have to test this, but this should prompt for missing links. Added this to the backlog.
  • Does VS have a way to constrain every action to one specified angle?
    @b77 Thanks - I like the location of this option better than where illustrator has it. Rotating the canvas and keeping the created vectors and such in a normal view can be great for certain things. I wonder if an option to keep the canvas in normal view and rotate the material created might also be a good option to add eventually in some capacity
  • VS Internal Font Manager Dependent on 3rd Party Font Manager
    @Boldline said in VS Internal Font Manager Dependent on 3rd Party Font Manager: folders contained 30k fonts each Yes, this may cause slowdowns.
  • One stylus pen issue fixed - can this second issue also be fixed?
    @VectorStyler Thank you - I know you'll find the best solution. I appreciate you hearing me out
  • Difficulty adding node to existing path with double click
    @VectorStyler so far is always been a literal double tap, but I will try adding that function to a stylus button and see how that goes. I agree the stylus overall is less precise and using a stylus button might help in multiple ways
  • How to break a connexion between clone objects
  • How to Edit Text Background?
    @VectorStyler said in How to Edit Text Background?: @b77 @gotanidea The modal character options editor has a bug when working with background / underline and other decorators. Some drop downs don't open. The fix for these will be in the next build. Good to know that. Thanks again
  • More Keyboard Shortcut Conflicts
    25
    32k Views
    @Igull
  • Rendering artifacts with VS
    @Harry Can be replicated.
  • width dialogs
    T
    @VectorStyler Thanks for getting on it. Looking forward to the next build!
  • shape paint and gaps
    T
    @VectorStyler Thanks for confirming there's a bug. Another issue that might be related is that the "Close Shapes" value in the "Shape Paint Options" dialog does not persist. It gets reset back to the same very small value whenever the dialog is closed and re-opened. @b77 That's a slick workaround you came up with!
  • Trace B/W shape without white
    @postdes 'Ignore White' is the correct setting for this, not 'Extract Alpha'. My apologies.
  • Transparent Backgrounds?
    Ahh! That's what I was looking for! I think I was thrown by the term "grid" since I usually think of the grid as a separate design guide element than the background. Thanks!
  • Reset Transform
    @Igull
