• Canvases, artboards, clones, actions - designs for Redbubble
    @VectorStyler Thanks for this comprehensive answer! Still a long way ahead, but when I master references I feel like i could be great shortcut.
  • How to I make sure Favorite Fonts display?
    @Boldline You didn't by any chance click the 'Favorite Font' entry in the Character panel's menu? That is a checkmark, and if you click it, the font is deleted from the Favorites list.
  • How to draw "calligraphic" strokes with a stylus?
    @Harry Looks like the width profile goes through too much simplification in VS, for long paths. I will improve this.
  • Blends are not automatically transferred to cloned curves
    @VectorStyler said in Blends are not automatically transferred to cloned curves: @Subpath Just duplicating, or cloning the two ends will not carry the blend over. This is by design. that it does not work with duplicates is clear to me if I manually blend the cloned curves it works as desired but that the blending is not automatically is transferred to the cloned curves, if i blend the two orinal curves had me just wondered.
    I got this, by grouping the finished blend which made it easier to rotate (from the center I think vs from an edge). Quite a bit of tinkering. Not a bad result. Thanks for the help. 0_1670487017668_Abstract_Knot_Illus_Vctr_FINAL.vstyler
  • Disabling vertical flipping during text scaling?
    @encart I added this to the backlog, will do flipping only if both directions are flipped. @Boldline No option for this.
  • Trim and Join and .... Extend (once again)
    @VectorStyler said in Trim and Join and .... Extend (once again): @Harry Should it work for lines only, or for curves also? It would really need to work for curves too - that'll make it easier for you Neil
  • 1-bit Bitmap export been added to VS?
    @Boldline Got it!
  • Change dimensions for bounding box
    @Clausj Also interesting to open and to look at is the "Shape" Panel With it you can edit different parameters of the different Shapes that VS offers Menu > Panel > Shape
  • I lost gradient styles and presets from Gradient panel
    @Harry Just select a color in the Color panel or Palette panel. Make sure that no gradient color knob is selected in the gradient panel.
  • How to just trim/crop image fastest possible way?
    @b77 indeed, thats fast I did not know that either So, good to know
  • How to apply effects to other objects?
    26
    35k Views
    @Pat said in How to apply effects to other objects?: I think there is still enough space to get sharp pointed edges but no way by modulating the miter limit... another way ? The blunt corners are caused by open paths. At the highlighted locations, the nodes overlap, but the paths are actually open. Use the Node tool and the command in the context panel to connect the nodes.
  • About Artboards, Layers & Objects
    @postdes said in About Artboards, Layers & Objects: But what if I want to isolate the objects in a layer stack that are on 1 specific artboard? Is there a way to do this, or a preferences setting to change these things? It is not possible to limit objects to 1 specific artboard only (for now). In VS the artboards are similar to how they are done in Illustrator (for a single canvas). Probably it is easier to work with this model with some Illustrator background instead of Affinity. All objects on a canvas are part of a Layer hierarchy (layers at any depth, and groups) of that canvas. In VS, artboards are more like "guides", indicating areas for printing and /or exporting. A single canvas may contain any number of artboards, placed arbitrarily on the canvas. Objects can overlap multiple artboards, and the stacking order of objects across all artboards is the same. It is possible to clip objects to artboards, but this is just a "displaying" trick, and the object can still strech across multiple artboards (even if clipped on each). And about multiple canvases: yes, things get a bit complicated here. This part is more similar to what we have in InDesign with spreads (canvases) and pages (artboards). And I think the Corel multiple page model is also similar to this. But yes, it is possible to have multiple canvases in a single VS document each containing its own Layer hierarchy. Only one canvas can be visible in a document view, but multiple document views of the same document may show different canvases. Master canvases are similar to what we have as master pages in DTP apps. Sort of a template for canvas content. Reference canvases are "extra" canvases that are not included in printing or exporting, and can be used as a place for various assets like symbols, vector pattern or vector brush content, etc. Reference canvases become interesting once we get used to how styles and object roles work in VS (these are VS specific). For example, it is possible to "declare" all objects (with a name) on a reference canvas as symbols. Or all colors used to fill objects on a reference canvas as "color styles". And these remain dynamically linked: modifying them updates all their uses through the document.
  • Shape tool properties should not be affected by "transform strokes"
    @Boldline Do you have a recording of this, it might help identifying the issue.
  • Schoolboy Circle Question
    21
    27k Views
    @b77 said in Schoolboy Circle Question: Unfortunately trackpad users are stuck with no access to a context menu with this setting This is why the before / after mouse press differentiation of modifiers allows for covering more use cases.
  • How does arithmetic operations work in Transform panel?
    @Harry In the angle editor the units are just decorative. In the position / size the units always convert to [pt] and this causes the issues here. I will try to improve this.
  • Difficulty selecting small objects surrounded by others
    @VectorStyler I sent you the file by email. I was trying at first with the wacom stylus and then tried with mouse - it was easier with mouse but not by much
  • Align to Shape does not work as expected
    @VectorStyler works after convert to curve put i miss this Part here [image: 1669801829205-missing-part.png]
  • Repeat Move of nodes
    @Raven said in Repeat Move of nodes: then select other node/s and choose Repeat Move, the nodes move by the amount of the earlier object movement I think this might be a bug. I will try to replicate it and find a fix ASAP.
  • How do I switch back to text size preview when dragging with text tool?
    @b77 said in How do I switch back to text size preview when dragging with text tool?: That option enables text size preview when dragging and it's not working. ok - yes then we're on the same page. I wanted to be sure it was not just me who was having issues with it. Also wanted to be sure @VectorStyler was aware of the issue. thanks https://recordit.co/wWWD7odBwV
