• Object with two strokes, how to convert to curves ?
    @Pat Edit the stroke attributes or the shape? The stroke attributes can be edited in the Appearance panel: [image: 1669476567968-stroke.png] The shape cannot be edited separately. For that we instead should use the Offset Path live shape effect, and then convert to curves.
  • Transform Pivot Point Snapping
    @Igull said in Transform Pivot Point Snapping: I wonder if there is a preference on this that I might be missing No preference for this. I will try to find out what is the issue.
  • Distribute/Align Shapes Help
  • Object Style Preset
    @VectorStyler Yes its fill was set to zero, thats the effect I wanted. As I said after saving as preset I had tested the preset by applying to other shape and it was working ok.
  • Increasing the range of keyboard shortcuts by adding more keys
    Suggest looking to WordStar for inspiration.
  • New document setup - Why duplicates of the same data/parameters?
    @VectorStyler Well, I understand. In this case, why not remove the redundancies in the "Artboard options" window? It can be confusing to have all these different ways of changing/adjusting the same parameters whatever they are. It's not an issue, but at the beginning you always wonder if they are exactly the same settings.
  • does it make sense to have a zero width path brush stroke?
    does it make sense to have a zero width path brush stroke? No, not really, but there needs to be a lower limit.
  • Why can't I permanently change the colour panel to "RGB sliders"?
    @VectorStyler I will finish a drawing and I'll send you the file. You can then test colour gradient changes with the "undo" function.
  • Pattern brush.. Help
    @VectorStyler sent
  • How to improve VS performance ?
    @Pat There is no reason for the slowdown, other than a possible bug with some effect or gradient type. If you send me that document I will try to replicate this.
  • Editing a gradient colour
    @Jayanta-Das I will try to replicate this issue.
  • Paste --> Paste in place -... : why in "Placing"?
    @VectorStyler Ok but why not create a submenu in "Paste" for all "Paste..." instead of having it in "Placing", it's just that I expect to find all the "Paste 'something' " in the same submenu of the "Paste" menu... not a big deal anyway.
    I'm not sure, but I think the adjustment layers with effects is not a feature of other vector apps, but it does exist in Photoshop. It's awesome that we have adjustment layers in a vector graphics app.
  • After Boolean Intersect, no more objects
    @VectorStyler In fact, "intersection" works if I merge the two letters first. I can't keep them separated in two distinct layers. Nice ! [image: 1668668348315-618bef82-73b7-4127-91d1-cf0a1efe32a3-image.png]
  • Blending: how to get a specific path & not another ?
    @Pat Like your "VS" too very creative
    @Boldline In the context panel? I think it could be displayed. EDIT: but then there are the other attributes, like color, etc.
  • Curve/line & "break apart"
  • Number of blended object limited to 256 ?
    @Pat Yes, it is an (internal) configuration value. Will be increased.
  • Image as fill in appearance
    @Jayanta-Das It is possible to make a tiling pattern from an image. And to use it as a fill (clipped into a shape) with no styling, just apply the image on the object using the Links panel.
  • Locked layer: not totally locked ?
    @VectorStyler I've sent you the file.
