    @VectorStyler and yes, I wanted to move objects from a layer to another one.
  • Document in "mm" & text in "mm"
    @PatrickM said in Document in "mm" & text in "mm": Also, how can I adjust the frame to the text? No such option in VS, for now.
  • Snapping: how to get this...
    @VectorStyler File sent
  • Spanish Version
    @formulalatino I added this to the backlog. Will try to have translation by version 2.
    @Boldline said in editing the handles only of multiple nodes at same time - but not moving the nodes as well: pick certain preferences options and customize them in a dropdown folder Maybe in the future.
  • Deciding what part of separated path to keep and what to delete
    @Boldline When deleting a node, it will delete the segment before the node along the path direction.
    @VectorStyler said in How do I commit to changes made with warp tool and retain stroke attributes?: To get back to editing nodes, you need to convert to curves (again). thank you - I found where I got stuck. If the node editing tool is selected and used to select the warped shape, then pressing "convert to curves" will not work - you need to switch to the transform tool and then try "convert to curves" to have success
  • How could i switch off the " X " sign
    @VectorStyler thanks
    @Boldline A possibly fast solution is to just select an object that has an uniform width stroke, then drawing with the Pen tool after that should revert to that width (or to 1 pt width if the previous object has no stroke).
  • Selection Confusion
    @VectorStyler No, the cursor is a small curve with circle on top plus a mini regular cursor LOL. I've tried a vid, but it's not capturing the above cursor change for some reason. The cursor changes from a regular cursor when hovering, to this other cursor when shift is depressed. Neil [image: 1667833913633-screenshot-2022-11-07-at-10.52.38-resized.png]
  • Setting the unit of measurement in the export panel
    @Boldline Yes, at this phase it does not yet has any corners. First you must set a nonzero corner radius.
  • Change key commands?
    @jfraze When you don't find some feature or command you need, try the Search field under the Help menu (say, 'shortcuts'). If it's included, macOS will point it where it's located in the menus.
    @Boldline With two "separate at intersections" commands this corner was also separated. I opened a bug on this one, as one command should be sufficient.
    @Boldline Currently the Shift key keeps the line segments at certain angle, and node movement direction cannot be restricted. One way to work around this is to select those nodes, activate the Transform tool and move with that. I will try to change this to allow multiple node movement constrain for shift key, as limiting the segment angle does not make much sense in this case.
  • Layer transparency preview: difference between...
    ately
    @VectorStyler Thanks, I did not notice this preview checkbox, very helpful.
  • Question to PC & Windows users: Windows Ink & VS
    @PatrickM I was enabled for me be default (Intuos Pro S) that is how I used it. But the panel movement bug exists.
  • How to change mm in px (& vice versa)
    @PatrickM Looks like these options work only after the document was created. The Canvas -> Artboard Options command opens the same view. I will fix this ASAP.
  • Blend Transfer - delete a point of the curve
    @VectorStyler My first reflex was indeed the "delete" key. I should have thought about it and stayed on this problem but as I was trying to reproduce with VS what I did more than 10 years ago with AI, I was already thinking about what other effects I was going to affect, wondering where to find them, etc. I wanted to come back to this problem but the transformation of my blended object crashed VS. On restart, a crash report has been sent (had to be sent). The habit of working with AD where the deletion of such points is also done by the delete key. It would be nice to add this possibility for all curves.
  • Artboard - Size preset
    @PatrickM This can be replicated easily. it is a bug, added it to the backlog.
