  • Button for Select > Options > Allow Locked Objects
    @Boldline said in Button for Select > Options > Allow Locked Objects: all of the folders on the left side are named "Folder". Yes, these were not named as the name is not used anywhere else in the UI. I will add some default names for these.
  • Brush Format Options
    I see! So cool! Thanx [image: 1686404457650-e24ca035-8f3a-4aeb-81b6-b248c4c9d056-image-resized.png]
  • Streamlined VS Workspace
  • Ergonomics
    R
    EDIT: actually in full screen mode (and tablet mode for the future), these kind of things might help. I agree. "Would this be the right click menu?" There will be no need for context menu, toolbar icons will be what is in context, remaining toolbar items will be hidden. Toolbar is activated with context tool icons, trigger by what the user does ( trigger by selection e.g.) I hope I am clear, pardon me it is just a small idea to have more focus on the canvas and tools are in the background, and called in the UI when needed. Makes sense?
  • Gap Tool ideas
    @b77 said in Gap Tool ideas: Preferences > Editing Options 2 > Show Editor Popups displays the moving distance. So here is an example of where the popups being active would interfere in my work. I would turn this one off specifically and leave others on
  • Possible confusion finding preferences settings
    @Igull it is hardly original - it has been in use for several years now: https://www.google.com/search?q=ipadification
  • Tying the font size to the transform scaling of live text
    @VectorStyler Yes, the "direct shape transformation" is checked on. I also restarted VS fresh and had the same issue. [image: 1686160139731-dd91de10-a9c9-4d95-b4c2-326b7e7410d0-bld-2023-06-07-at-13.39.23-resized.png]
  • Aesthetic guideline for using shift modifier
    @Boldline Added this to the backlog of features.
  • Text wrap
    @Pat Added this to the backlog (the first request )
  • Margins & grids
    @VectorStyler Good to know. Maybe new/other layout features will be in VS 1.2 but it would be nice to be able to setup grids according to the margins. Thanks
  • Bleed, activate by default when selected
    @Pat Yes, (2) is in the backlog. Added (1) also.
  • Smart node deletion
    @Boldline Added this to the backlog. Whether the curve moves or not it also depends on its shape and if it can be approximated with a single curve.
  • Adding the option for "auto close" for pencil tool
    I want to clarify that I meant to say I would NOT set it as the default. But instead let it be an easy check to make on the contextual menu
  • Ten points for VectorStyler, my experience and ideas
    @b77 I love your idea for the node Indicator Shapes preferences! So fast and easy to see!
  • Request: Non-blocking sliders in color selection dialogs
    @Victor-Vector said in Request: Non-blocking sliders in color selection dialogs: @Ingolf, indeed, a strange anomaly. On my Win11 machine I do not have this occurring. I noticed in your post's footer you list both a Mac and a Win11 OS. Are you running VectorStyler on both OSs? Do you get the same anomaly on both? My intuition was right that it was a configuration issue, so I didn't check before Csaba gave the above advice. I only turn on my (fast) Windows machine when I have no other choice.
  • Copying and pasting path segments
    @William-Kansepa said in Copying and pasting path segments: I am thinking that the Shape Editor Tool exhibits the same traits as the Direct Selection Tool in AI? Similar, yes. And for pasting a copied path section: select a node (preferably an ending node) and the path is pasted as a continuation there. Otherwise, it is pasted as a new object.
    @Boldline I tested this, and unless the image is embedded, the file name should be the first in the tooltip.
  • Interesting way to quickly create a grid of shapes
    I think i mentioned this somewhere before Magix Graphics Designer (Xara) also have an interesting way to create a grid of shapes here a video
  • Should the "x" lock symbols color correspond to the layer color?
    @VectorStyler Following up on this topic. Sometimes I've noticed the "x's" being the same color as the layer color - but more often than not, they are always black, even when I adjust the layer color.
