  • Grid creator method
    Just for the record The last time I launched Magix Graphics Designer 19 i noticed that there was something similar. Here a Video [image: 1675923456079-xara-duplication.png]
  • Add a slider control to the stroke align option in Stroke panel?
    @b77 we can all have sliders!
  • Aligning text to shape
    @VectorStyler said in Aligning text to shape: @Boldline Certainly it is Awesome Can't wait! 1.2 is sounding like an epic update
  • Bleed - visible by default
    Agreed, in the View menu, Margins should be moved down one spot and a separator added, so that Margins and Guides are together.
  • Page layout: columns guides & gutters
    @Subpath Thanks to take the time to give a feedback Yes I know this but the idea is to organize an artboard for page layout with specific guides for that purpose While waiting for this feature (hopefully) I’ll organize guides & grids.
  • Reshape vector paths
    @Boldline Something like this already exists: try the Outline ZigZag for zigzag and wave shape overlays. try the Overlay shape filter to use custom shape overlays. the only issue here is that you need to define your own custom shape profiles. Here is an example of using custom overlay shapes: Select the waving ellipse, and in the Shape Effects panel, open the Overlay shape filter options. Here (among other options) it is possible to change the Shape to any open shape that has the "Shape" role. Two examples are on the top of the artboard, and listed in the Shape drop down. 0_1675235597572_overlayshape1.vstyler
  • Align Centre
    @Igull would like to mention that it is also possible to delete single steps in an action recording
  • File -> Open recent : option to delete from the list
    @Pat said in File -> Open recent : option to delete from the list: I didn't want to refer to Affinity yet, but I also like the way these applications handle missing files. It would suit me perfectly. This one thing they did right. The most common scenario here is that I actually want to clean the list from now irrelevant files and removed files. Then I open the one or two files I want to stay there, clear the list, and make a minor change then undo it to the two open files… then save them. A few seconds of manual work. I also wanted to suggest a feature similar to that in Affinity, when a file in the list cannot be opened but forgot. It would be a great supplement to the total destruction method behind clear list.
  • Add "expand live text" checkbox to export panel?
    @b77 thanks! Apparently I was not doing enough investigating prior. i'll be sure to use that more going forward
  • Clarification in a Warning panel
    @Boldline Will rename to "Save As"
  • Bleed, margins: an option to link the values
    @VectorStyler of course, it would be great
  • Arbitrary pen nib shape
    @Raven The bristle brush shape editor has a bug, fix will be in the next build.
  • From Apple Store
    Good, you're great!
  • "Reset" option in Transform panels/menus
    @Pat Added this to the features backlog.
  • Link content warning improvements
  • Smooth Tool like in Illustrator
    5 Votes
    @VectorStyler said in Smooth Tool like in Illustrator: @Boldline Added this to the backlog. Neil
  • How to see long names for selected images
    @b77 said in How to see long names for selected images: @VectorStyler The full name could be shown in a tooltip when you hover the selection info area in the context panel. Added this to the backlog.
  • Corner tool possibilities
    @Subpath said in Corner tool possibilities: so mission accomplished Yes the immediate mission was accomplished! Hoping @VectorStyler can address the minor but important suggestion for improvement and the error with the top row far right example that seemed to overinflate
    @VectorStyler Thanks Admin
  • Adobe Illustrator's Quick Preview When Moving Complex Object Around
