  • A node selection issue that slows node editing
    @VectorStyler said in A node selection issue that slows node editing: The problem is that click+drag should be able to move nodes / segments. OK, but by 'click-and-drag' i meant 'box select'. That should not select and bend any segment of any other shape than the selected one. If it's doable…
  • A few thoughts about Color panel
    @VectorStyler said in A few thoughts about Color panel: @Harry Would this mean that holding Control would pick in the spectrum along the same horizontal / vertical axis as the current color? Yes What about the hue spectrum (circle)? It could work as the ruler also - holding control gives perfectly opposite (complementary) color on the circle. But maybe others would have some suggestions?
  • Superselect / Subselect
    @Raven Added to the backlog, should not be a difficult thing to have.
  • EPS option for Illustrator
    @ash-f Added this to the backlog. This is probably doable, bit it is a larger task. AI file format was documented up 1998 for AI7 and AI-EPS.
  • Brush "live" randomization / variation
    27
    42k Views
    @b77, @Harry, @VectorStyler Hi As a source for inspiration, for modulate Strokes, the painting program Black Ink came to mind. "Black Ink" uses a kind of controller nodes to modulate brushes to set and control random strokes and has a node system for layers. [image: 1670593437191-black-ink-1.png] Here are some videos Video about the Brush Controllers: Black Ink Brush Controllers Video about Black Inks Layer Nodes: Black Ink Layer Nodes Scattering a Brush may also be interesting her a Video about it Scattering a Brush with Controllers
    @Raven said in "Zoom Tool Click Zooms Out" preference to also work with the temporary zoom tool: doesn't recognise the addition of the Option key for zooming out Yes, this is caused by deactivating the temporary zoom if other keys are pressed. I added this, will try to fix it ASAP.
  • Option to pin open the dialog box for icons in the UX
    @b77 yes that is true... and maybe that is the best solution. Part of me likes the ability to just open it and have it there as opposed to tearing it off and finding a place for it.
  • Effects "Randomizer"
    @Harry , @b77 can not resist to contribute to this Do you know Native Instruments "Reaktor"? A program that allows you to create your own software synth maybe VS will look something like this in the future ? [image: 1670439157079-reaktor-synth.png]
  • Reconsider some value sliders
    @Jayanta-Das said in Reconsider some value sliders: In Affinity Designer it is Alt+Ctrl+Left Click and drag. This is very usefull if I set this key press combination in Wacom pen button then I can simply click the button, hover over and move left and right to resize brush. Recording Problem with these Affinity multi-key shortcuts are that they are so easy to forget and incredibly annoying to hold down. Photoshop + Capture One Pro: right click, easy to use pop-up with options and preview of size (at least in CO), done. Impossible to forget, easy to use.
  • Adapt some Preferences options on first run of the app
  • Using more distinguishable terms in the palettes menu
    @Boldline Yes, this will be renamed.
  • "Live" preview of transform values
    In Color panel there is a lag between opacity slider movement and object's opacity change. On the other hand, in Object/Object Options pop up, there is smooth opacity change - that's I like - but lag with slider circle.
  • Toggle shortcut for Greyscale display mode
    @Ingolf said in Toggle shortcut for Greyscale display mode: I could easily live with a static one with a 'refresh' button. This is easily doable, as image histogram extraction and histogram view (separately) already exists.
  • Duplicating Guides by Using Ctrl+D
    Ok my bad - I misunderstood. I was copying objects.
  • Transform modals to remember last use of transform tools
    @Raven Added this to the backlog. Not sure about the floating panel mode. Maybe having a different "mode" set from the panel menu, for the existing Transform panel
  • Mirror option
    @Boldline Something similar can already be done using object reference, or maybe a reference to a layer, and then transforming / mirroring the reference.
  • A specific panel for text styles
    @Pat Yes, I think these could go into the Panels -> Text submenu.
    @Boldline Yes, this is doable, and already exists in a different form. Select multiple palette files in Finder and drag&drop over the VS window.
  • Would it be possible to move B&W colours...
    @Pat Added to the backlog.
