• Persistence and Tenacity
    syllieS
    @Ayo Besides what @Boldline mentioned, I just wanted to say how it makes me happy to see influx of new (serious) testers that run VS through its moves and add to the conversation what can be done better / different / would improve their workflows. I too am testing VS on and off over a couple of years now and can see the large amount of improvements that have been realized in this time. And not just improvements, also extra functionality (such as support for Japanese typography) and things that we cannot do easily in other programs. Contributions like yours are invaluable and help to shape VS into an outstanding application.
  • Font metrics ascender should stick to text frame
    @VectorStyler Maybe I overstep my role, but I was still thinking about this (mentioned it also in the mis-leading pdf) and thought that the cause might lie in the use of the font metrics font size 'Height' that includes the fonts internally specified leading specified by the font designer. Advanced DTP programs can control the line spacing in terms of point size and use body height (sum acender + decender), but word processors default to single line-spacing are using the build-in line-spacing specified by the font designer. It is important NOT to use the so-called 'default build-in line-height' wich is basically a font designer's personal preference which is irrelevant and undesirable in a professional environment. Leading is highly dependent on line width and use/medium. Maybe I am wrong, I am not a developer. "Maybe I heard the clock chime, but do not know where the clapper is" (dutch proverb) I'm just worried.
  • Unit Soup
    @Ayo said in Unit Soup: When I specify units for Type as points I want to see points (supervisory). Found the bug. The various leading, etc fields use the wrong defaults. Will be fixed.
  • Artboard stress
    @Ayo said in Artboard stress: Stack order in panel represents print/export order. That's correct, isn't it? Yes, stack order in Canvas& Artboards panel.
  • [Bug] Strange behaviour of scrolling lists
    @encart Clearly a bug, added it to the backlog.
  • Font color in text frame
    @VectorStyler OK, could be that the mockup is oversimplifying things — this background color needs to be added as content that can accept transparency masks, effects, etc, right?
  • two Buttons in layer panel are too similar
  • Was the transform panel removed?
    @Boldline said in Was the transform panel removed?: If I wanted to add it back in again at the top, would that be in the contextual menu bar or can we also alter the very top menu bar area? This can be edited with the Customize Toolboxes command and in Toolbox select the "Context Panel" mode.
  • Stable font for Typotesting
    @VectorStyler Now you beat me! I ask you an inch, and you go 3 inches. I will be coming back to this later.
  • Paste Text Bug
    @Ayo If it crashes with this again, back up the resources folder. It might be some settings causing this.
  • Split Object Shape on gradients - a bug?
    @Harry Not a bug. Currently the gradient is aligned to the object shape. I will try to improve this in the future.
    @Harry context panel restricted by design. CMYK, HSB etc. values in color panel I have to check why this happens (could be also by design to restrict accidental changes).
    @Harry Replicated on Windows. It should not show these if there are no condition variables defined, can be ignored. Will be fixed ASAP.
  • beta 1.2.003 update
    6 Votes
    @Harry said in beta 1.2.003 update: In the profile editor view, it doesn't work at all. Replicated on Windows. I will fix this ASAP. As a workaround, drag the node out of the profile area to the left or right to delete.
  • Trouble with Snapping Icons
    @Ayo cool, like them
  • Pen tool icon/pointer
    @VectorStyler this will be difficult because when I click outside the VS workspace, I get the correct icon (which may disappear but always comes back)... I mentioned this issue because I thought it was permanent but it ends up working... so, weak prority to that
  • Did the brush width indicator change? I don't see a difference
    ok maybe I'm all set - I've updated the build since then and the icon for the path brush and eraser are both the current circle with brush inside and no longer the elongated cross hairs. Maybe I need to play around with it more but the two settings do not seem as different anymore from one another. I will test it more and get back to you
  • Serif Font while font selector says Arial
    @Ayo Added this to the backlog.
  • Contour stroke: bug?
    @VectorStyler I have already forwarded the file to you previously if you want to test it
  • Artboard Label Settings
    Suggest putting the options in tabs on the right side - "Sizing", "Appearance", "Artboard Label", "Slice Label" perhaps? As long as there are only a few, logically organized tabs in a section that is still a logical and accessible way to organize these. Just need to be careful that it doesn't get out of control and lead to one of the three cardinal sins of tabbing: scrolling tabs, multiple rows of tabs or tabs within tabs.
