• Issue adapting the size of the panels
    @VectorStyler perhaps to help: adjusting the width of the innermost column can be done by clicking on the top (see image). If you click and drag below, the width of the other (more external) column is modified (and the width of the innermost column remains unchanged). [image: 1701949318412-p-resized.jpg] Edit: well... it doesn't work 100% either, but once in a while it does.
  • Restoring iconified panel not working, also width changes
    @syllie Yes, this can be replicated on windows. It occurs for docked, iconified panels. As a workaround: try clicking as much as possible to the left side of the icon (close to the double line). I will fix this in the next build.
  • Settings not applied or remembered
    @VectorStyler said in Settings not applied or remembered: Exit the app, and remove these (or back them up if you have important customization), and then restart the app with (will have the default workspace). Yes that worked
  • Document setup & Guidelines
    @Pat said in Document setup & Guidelines: Here another view, with the canvas & artboard panel: I will try to replicate this issue. It could be related to the recent (last build) changes on how the artboard options are edited.
  • beta 1.2.007
    7 Votes
  • 'Layer from group' and 'Release to layers' don't seem to work
    @Ayo said in 'Layer from group' and 'Release to layers' don't seem to work: Maybe better tooltip? Yes
  • Toolbox behavior beta 6, macOS
    @Ingolf Somhow this could be a similar issue as the one in https://www.vectorstyler.com/forum/topic/3808/settings-not-applied-or-remembered Here I can dock the toolbox both on the left and right, next to panels correctly. For some reason the workspace is not handled correctly. Exit the app, remove the settings and workspace files and restart.
  • Panels getting wider
    @FastVector I will try to replicate this. One thing about iconified panels: these can still be resized, with the text showing if the size is large enough. But by default, it should display only the icon.
  • Docked Panels are cut off on the right side
    After a restart, the panels are not cut off anymore. I still can't make the column wider, though (it works in 1.1.115). *edit I can make the column wider; there seems to be a substantial delay before I can do it when I hover the cursor over the divider.
  • There is an issue with flipping repeater content
    @VectorStyler Thanks. Fixed in 1.2.006
  • Adding action to application toolbox crops the first column of icons
    @VectorStyler said in Adding action to application toolbox crops the first column of icons: It Could be caused by that single tool group at the bottom Could be, because after adding second action to this tool group, toolbox isn't cropped anymore
  • Panel gets narrower
    @Pat I will try to replicate this still. There is always some other condition for these.
  • Artboard "Show Size in Label" option changes artboards' dimensions
    @Harry Yes, seems that the artboards retained their format (should not) after drawing. Will be fixed ASAP
  • Extended crosshairs still an issue in the new beta build
    @VectorStyler I didn't mind the crosshairs actually, just didn't want them to extend far beyond the size of the circle. Having it be an empty circle might be ok too
  • update 1.2.006
    8 Votes
    @VectorStyler There was an entry for VS 1.2.006 in the Windows App Uninstaller. I uninstalled both betas, downloaded it again, and the beta works now.
  • Shape effect, option panel
    24
    36k Views
    @Pat said in Shape effect, option panel: the strokes suddenly disappeared and it was impossible to get them back. I will try to replicate this.
  • Little panel icon displaying options
    @Pat Can be replicated. Seems to work only of the panel is not iconified.
  • Select-menu out of line and can't find customize in view-menu
    @Harry Thanks for your reply. 100% scaling or the mousewheel helped me for now to solve the problem with the 'customize' menu.
  • Search next/previous options for search bars
    @Harry Thanks for the suggestion. I added this to the backlog.
  • Tool Indicator setting revert to same Shape
    @Ayo Found the root cause of this issue, fix will be in the next build.
